Topic "I need SFTP to create remote directories via command line"
unabletostay
I'm using 5.1.3.0 via command line on a growing number of servers to backup a specific location. I'm using a Windows environmental variable %computername% so minimise customisation of the script per server.
I'm finding that when attempting to transfer to /%computername%/Data that because the /%computername% doesn't exist it fails. This makes sense and from my understanding this is by design. Is there however any switches I can use to change this so it does create the directory?
Script below:
winscp.com /log=log.txt /script=backupScript.txt
backupScript.txt
option batch abort
open username:password@server
synchronize remote -delete "E:\Data" "/%computername%/Data"
Thanks in advance for your help. Smile
option batch continue
mkdir /%computername%/Data
option batch abort
But you still get an error exit code and error record in the log.
Clean solution would be to use Session.FileExists from WinSCP .NET assembly:
http://winscp.net/eng/docs/library_session_fileexists
unabletostay
Thank you kindly Smile
