Topic "powershell transfer txt file always binary"
dafinch
I'm trying to transfer a text file from a windows server to a linux server. I am able to transfer the file but when I look at the file is a binary file.
$transferOptions.TransferMode = [WinSCP.TransferMode]::Ascii
$transferResult = $session.PutFiles("c:\test.txt", "/tmp/", $FALSE, $transferOptions)
I've got the transfermode set to Ascii. Not sure what i'm doing wrong.
What do you mean by "file is a binary file"?
dafinch
When I attempt to look at the file from a linux prompt I get a prompt that "text.txt" may be a binary file. See it anyway.
And instead of seeing Hello World! I see
<FF><FE>h^@e^@l^@l^@o^@ ^@w^@o^@r^@l^@d^@!^@^M^@
test.txt (END)
Usually when I less a text file I don't see that warning and just see the text.
Sorry I figured out my issue. The files needed to be converted from dos format cr/lf to unix. Once that was done they worked.
Well, that's what the ascii transfer mode should do for you automatically. Please attach a complete session log file.
