Topic "Unable to connect to ftps"
Rajnesh
The same FTPS connection works fine with FileZilla (However it fails with wincp).
Encryption : TLS Explicit connection
It seems that we are missing appropriate ciphers that can be used with winscp
Logs :-
. 2013-03-22 05:28:44.429 --------------------------------------------------------------------------
. 2013-03-22 05:28:44.429 WinSCP Version 5.1.3 (Build 2881) (OS 5.1.2600 Service Pack 3)
. 2013-03-22 05:28:44.429 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2013-03-22 05:28:44.429 Local account: HOME\Administrator
. 2013-03-22 05:28:44.429 Working directory: C:\Documents and Settings\Administrator.HOME\Desktop
. 2013-03-22 05:28:44.429 Command-line: "C:\Program Files\WinSCP\WinSCP.exe"
. 2013-03-22 05:28:44.429 Time zone: Current: GMT+0, Standard: GMT+0, DST: GMT+1, DST Start: 3/31/2013, DST End: 10/27/2013
. 2013-03-22 05:28:44.429 Login time: Friday, March 22, 2013 5:28:44 AM
. 2013-03-22 05:28:44.429 Session name: rsiwal@172.31.240.29 (Modified stored session)
. 2013-03-22 05:28:44.429 Host name: 172.31.240.29 (Port: 21)
. 2013-03-22 05:28:44.429 User name: rsiwal (Password: Yes, Key file: No)
. 2013-03-22 05:28:44.429 Tunnel: No
. 2013-03-22 05:28:44.429 Transfer Protocol: FTP
. 2013-03-22 05:28:44.429 Ping type: C, Ping interval: 30 sec; Timeout: 60 sec
. 2013-03-22 05:28:44.429 Proxy: none
. 2013-03-22 05:28:44.429 FTP: FTPS: Explicit TLS; Passive: Yes [Force IP: A]
. 2013-03-22 05:28:44.429 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2013-03-22 05:28:44.429 Cache directory changes: Yes, Permanent: Yes
. 2013-03-22 05:28:44.429 DST mode: 1
. 2013-03-22 05:28:44.429 Session upkeep
. 2013-03-22 05:28:44.510 Connecting to 172.31.240.29 ...
. 2013-03-22 05:28:44.510 m_pSslLayer changed state from 0 to 1
. 2013-03-22 05:28:44.510 m_pSslLayer changed state from 1 to 2
. 2013-03-22 05:28:44.510 m_pSslLayer changed state from 2 to 4
. 2013-03-22 05:28:44.560 Connected with 172.31.240.29, negotiating SSL connection...
< 2013-03-22 05:28:44.560 220 Hello.
> 2013-03-22 05:28:44.560 AUTH TLS
< 2013-03-22 05:28:44.560 234 Proceed with negotiation.
. 2013-03-22 05:28:44.560 SSL_connect: SSLv3 read server hello A
. 2013-03-22 05:28:44.560 SSL_connect: SSLv3 read server certificate A
. 2013-03-22 05:28:44.560 SSL_connect: SSLv3 read server certificate request A
. 2013-03-22 05:28:44.560 SSL_connect: SSLv3 read server done A
. 2013-03-22 05:28:44.560 SSL_connect: SSLv3 write client certificate A
. 2013-03-22 05:28:44.560 SSL_connect: SSLv3 write client key exchange A
. 2013-03-22 05:28:44.560 SSL_connect: SSLv3 write change cipher spec A
. 2013-03-22 05:28:44.560 SSL_connect: SSLv3 write finished A
. 2013-03-22 05:28:44.560 SSL_connect: SSLv3 flush data
. 2013-03-22 05:28:44.560 SSL_connect: SSLv3 read server session ticket A
. 2013-03-22 05:28:44.560 SSL_connect: SSLv3 read finished A
. 2013-03-22 05:28:44.560 Connection failed.
. 2013-03-22 05:28:44.560 Got reply 1004 to the command 1
* 2013-03-22 05:28:44.620 (EFatal) Connection failed.
* 2013-03-22 05:28:44.620 Connection failed.
* 2013-03-22 05:28:44.620 Proceed with negotiation.
. 2013-03-22 05:28:49.697 Internal error: Connect called while still connected
. 2013-03-22 05:28:49.697 Connection failed.
. 2013-03-22 05:28:49.697 Got reply 3004 to the command 1
* 2013-03-22 05:28:49.747 (EFatal) Connection failed.
* 2013-03-22 05:28:49.747 Internal error: Connect called while still connected
* 2013-03-22 05:28:49.747 Connection failed.
. 2013-03-22 05:28:54.844 Session upkeep
. 2013-03-22 05:28:54.915 Connecting to 172.31.240.29 ...
. 2013-03-22 05:28:54.915 m_pSslLayer changed state from 0 to 1
. 2013-03-22 05:28:54.915 m_pSslLayer changed state from 1 to 2
. 2013-03-22 05:28:54.915 m_pSslLayer changed state from 2 to 4
. 2013-03-22 05:28:54.965 Connected with 172.31.240.29, negotiating SSL connection...
< 2013-03-22 05:28:54.965 220 Hello.
> 2013-03-22 05:28:54.965 AUTH TLS
< 2013-03-22 05:28:54.965 234 Proceed with negotiation.
. 2013-03-22 05:28:54.965 SSL_connect: SSLv3 read server hello A
. 2013-03-22 05:28:54.965 SSL_connect: SSLv3 read server certificate A
. 2013-03-22 05:28:54.965 SSL_connect: SSLv3 read server certificate request A
. 2013-03-22 05:28:54.965 SSL_connect: SSLv3 read server done A
. 2013-03-22 05:28:54.965 SSL_connect: SSLv3 write client certificate A
. 2013-03-22 05:28:54.965 SSL_connect: SSLv3 write client key exchange A
. 2013-03-22 05:28:54.965 SSL_connect: SSLv3 write change cipher spec A
. 2013-03-22 05:28:54.965 SSL_connect: SSLv3 write finished A
. 2013-03-22 05:28:54.965 SSL_connect: SSLv3 flush data
. 2013-03-22 05:28:54.965 SSL_connect: SSLv3 read server session ticket A
. 2013-03-22 05:28:54.965 SSL_connect: SSLv3 read finished A
. 2013-03-22 05:28:54.965 Connection failed.
. 2013-03-22 05:28:54.965 Got reply 1004 to the command 1
* 2013-03-22 05:28:55.025 (EFatal) Connection failed.
* 2013-03-22 05:28:55.025 Connection failed.
* 2013-03-22 05:28:55.025 Proceed with negotiation.
Rajnesh
ssl_enable=YES
allow_anon_ssl=NO
force_local_logins_ssl=YES
force_local_data_ssl=YES
ssl_ciphers=HIGH
ssl_tlsv1=YES
ssl_sslv2=NO
ssl_sslv3=NO
rsa_cert_file=/etc/vsftpd/vsftpd.pem
require_ssl_reuse=NO
pasv_enable=YES
pasv_min_port=50000
pasv_max_port=50999
Ian Bamforth
Was there an answer to this?
I am experiencing a similar issue.
All works fine with filezilla, but winscp fails to present the certificate
Here is my log file
. 2013-07-12 07:31:11.524 WinSCP Version 5.1.5 (Build 3261) (OS 5.1.2600 Service Pack 3)
. 2013-07-12 07:31:11.524 Configuration: G:\Portable\File Transfer\WinSCP\WinSCP.ini
. 2013-07-12 07:31:11.524 Local account: !!!
. 2013-07-12 07:31:11.524 Working directory: !!!
. 2013-07-12 07:31:11.524 Process ID: 7072
. 2013-07-12 07:31:11.524 Command-line: !!!
. 2013-07-12 07:31:11.524 Time zone: Current: GMT+1, Standard: GMT+0, DST: GMT+1, DST Start: 31/03/2013, DST End: 27/10/2013
. 2013-07-12 07:31:11.524 Login time: 12 July 2013 07:31:11
. 2013-07-12 07:31:11.524 --------------------------------------------------------------------------
. 2013-07-12 07:31:11.524 Session name: !!!
. 2013-07-12 07:31:11.524 Host name: !!!!
. 2013-07-12 07:31:11.524 User name: !!!!
. 2013-07-12 07:31:11.524 Tunnel: No
. 2013-07-12 07:31:11.524 Transfer Protocol: FTP
. 2013-07-12 07:31:11.524 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2013-07-12 07:31:11.524 Proxy: none
. 2013-07-12 07:31:11.524 FTP: FTPS: Explicit TLS; Passive: Yes [Force IP: A]
. 2013-07-12 07:31:11.524 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2013-07-12 07:31:11.524 Cache directory changes: Yes, Permanent: Yes
. 2013-07-12 07:31:11.524 DST mode: 1; Timezone offset: 0h 0m
. 2013-07-12 07:31:11.524 Session upkeep
. 2013-07-12 07:31:11.602 Connecting to !!!:990 ...
. 2013-07-12 07:31:11.602 m_pSslLayer changed state from 0 to 1
. 2013-07-12 07:31:11.602 m_pSslLayer changed state from 1 to 2
. 2013-07-12 07:31:11.742 m_pSslLayer changed state from 2 to 4
. 2013-07-12 07:31:11.789 Connected with !!!:990, negotiating SSL connection...
< 2013-07-12 07:31:11.961 220 (vsFTPd 2.0.5)
> 2013-07-12 07:31:11.961 AUTH TLS
< 2013-07-12 07:31:12.179 234 Proceed with negotiation.
. 2013-07-12 07:31:12.414 SSL_connect: SSLv3 read server hello A
. 2013-07-12 07:31:12.414 SSL_connect: SSLv3 read server certificate A
. 2013-07-12 07:31:12.414 SSL_connect: SSLv3 read server certificate request A
. 2013-07-12 07:31:12.414 SSL_connect: SSLv3 read server done A
. 2013-07-12 07:31:12.414 SSL_connect: SSLv3 write client certificate A
. 2013-07-12 07:31:12.414 SSL_connect: SSLv3 write client key exchange A
. 2013-07-12 07:31:12.414 SSL_connect: SSLv3 write change cipher spec A
. 2013-07-12 07:31:12.414 SSL_connect: SSLv3 write finished A
. 2013-07-12 07:31:12.414 SSL_connect: SSLv3 flush data
. 2013-07-12 07:31:12.617 SSL_connect: SSLv3 read finished A
. 2013-07-12 07:31:12.617 Connection failed.
. 2013-07-12 07:31:12.632 Got reply 1004 to the command 1
* 2013-07-12 07:31:12.663 (EFatal) Connection failed.
* 2013-07-12 07:31:12.663 Connection failed.
* 2013-07-12 07:31:12.663 Proceed with negotiation.
TimL
thanks for WinSCP! I also have a problem to connect to Prodtpd using FTPS. Can you fix it? Filezilla is working well!
. 2013-08-23 02:01:17.001 --------------------------------------------------------------------------
. 2013-08-23 02:01:17.001 WinSCP Version 5.1.7 (Build 3446) (OS 6.0.6002 Service Pack 2)
. 2013-08-23 02:01:17.001 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2013-08-23 02:01:17.001 Local account: LAPTOP\User
. 2013-08-23 02:01:17.001 Working directory: C:\Program Files\WinSCP
. 2013-08-23 02:01:17.001 Process ID: 7248
. 2013-08-23 02:01:17.001 Command-line: "C:\Program Files\WinSCP\WinSCP.exe"
. 2013-08-23 02:01:17.001 Time zone: Current: GMT+2, Standard: GMT+1, DST: GMT+2, DST Start: 31.03.2013, DST End: 27.10.2013
. 2013-08-23 02:01:17.001 Login time: Freitag, 23. August 2013 02:01:17
. 2013-08-23 02:01:17.001 Session name: root@192.168.178.199 (Stored session)
. 2013-08-23 02:01:17.001 Host name: 192.168.178.199 (Port: 21)
. 2013-08-23 02:01:17.001 User name: root (Password: Yes, Key file: No)
. 2013-08-23 02:01:17.001 Tunnel: No
. 2013-08-23 02:01:17.001 Transfer Protocol: FTP
. 2013-08-23 02:01:17.001 Ping type: C, Ping interval: 30 sec; Timeout: 20 sec
. 2013-08-23 02:01:17.001 Proxy: none
. 2013-08-23 02:01:17.001 FTP: FTPS: Explicit SSL; Passive: Yes [Force IP: +]; List all: A
. 2013-08-23 02:01:17.001 Session reuse: Yes
. 2013-08-23 02:01:17.001 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2013-08-23 02:01:17.001 Cache directory changes: Yes, Permanent: Yes
. 2013-08-23 02:01:17.001 DST mode: 1; Timezone offset: 0h 0m
. 2013-08-23 02:01:17.048 Session upkeep
. 2013-08-23 02:01:17.157 Connecting to 192.168.178.199 ...
. 2013-08-23 02:01:17.157 m_pSslLayer changed state from 0 to 1
. 2013-08-23 02:01:17.157 m_pSslLayer changed state from 1 to 2
. 2013-08-23 02:01:17.157 m_pSslLayer changed state from 2 to 4
. 2013-08-23 02:01:17.220 Connected with 192.168.178.199, negotiating SSL connection...
< 2013-08-23 02:01:17.220 220 ProFTPD 1.3.4a Server (Debian) [192.168.178.199]
> 2013-08-23 02:01:17.220 AUTH SSL
< 2013-08-23 02:01:17.220 234 AUTH SSL successful
. 2013-08-23 02:01:17.220 SSL_connect: SSLv3 read server hello A
. 2013-08-23 02:01:17.220 SSL_connect: SSLv3 read server certificate A
. 2013-08-23 02:01:17.220 SSL_connect: SSLv3 read server key exchange A
. 2013-08-23 02:01:17.220 SSL_connect: SSLv3 read server done A
. 2013-08-23 02:01:17.220 SSL_connect: SSLv3 write client key exchange A
. 2013-08-23 02:01:17.220 SSL_connect: SSLv3 write change cipher spec A
. 2013-08-23 02:01:17.220 SSL_connect: SSLv3 write finished A
. 2013-08-23 02:01:17.220 SSL_connect: SSLv3 flush data
. 2013-08-23 02:01:17.266 SSL_connect: SSLv3 read finished A
. 2013-08-23 02:01:17.266 Connection failed.
. 2013-08-23 02:01:17.266 Got reply 1004 to the command 1
* 2013-08-23 02:01:17.282 (EFatal) Connection failed.
* 2013-08-23 02:01:17.282 Connection failed.
* 2013-08-23 02:01:17.282 AUTH SSL successful
TimL
Now I have signed in the forum. Perhaps you can send me the debug version, as well.
Can you attach a full session log from 5.2.3 beta?
TimL
Thanks for the answer! Of course I can:
. 2013-08-27 21:06:30.929 --------------------------------------------------------------------------
. 2013-08-27 21:06:30.929 WinSCP Version 5.2.3 (Build 3436) (OS 6.0.6002 Service Pack 2)
. 2013-08-27 21:06:30.929 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2013-08-27 21:06:30.929 Local account: LAPTOP\Tim
. 2013-08-27 21:06:30.929 Working directory: C:\Program Files\WinSCP
. 2013-08-27 21:06:30.929 Process ID: 1744
. 2013-08-27 21:06:30.929 Command-line: "C:\Program Files\WinSCP\WinSCP.exe"
. 2013-08-27 21:06:30.929 Time zone: Current: GMT+2, Standard: GMT+1, DST: GMT+2, DST Start: 31.03.2013, DST End: 27.10.2013
. 2013-08-27 21:06:30.929 Login time: Dienstag, 27. August 2013 21:06:30
. 2013-08-27 21:06:30.929 Session name: 192.168.178.199 (Modified site)
. 2013-08-27 21:06:30.929 Host name: 192.168.178.199 (Port: 21)
. 2013-08-27 21:06:30.929 User name: root (Password: Yes, Key file: No)
. 2013-08-27 21:06:30.929 Tunnel: No
. 2013-08-27 21:06:30.929 Transfer Protocol: FTP
. 2013-08-27 21:06:30.929 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2013-08-27 21:06:30.929 Proxy: none
. 2013-08-27 21:06:30.929 FTP: FTPS: Explicit TLS; Passive: Yes [Force IP: A]; MLSD: A [List all: A]
. 2013-08-27 21:06:30.929 Session reuse: Yes
. 2013-08-27 21:06:30.929 TLS/SSL versions: SSLv2-TLSv1.2
. 2013-08-27 21:06:30.929 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2013-08-27 21:06:30.929 Cache directory changes: Yes, Permanent: Yes
. 2013-08-27 21:06:30.929 DST mode: 1; Timezone offset: 0h 0m
. 2013-08-27 21:06:31.022 Connecting to 192.168.178.199 ...
. 2013-08-27 21:06:31.022 TLS layer changed state from unconnected to connecting
. 2013-08-27 21:06:31.022 TLS layer changed state from connecting to connected
. 2013-08-27 21:06:31.085 Connected with 192.168.178.199, negotiating TLS connection...
< 2013-08-27 21:06:31.085 220 ProFTPD 1.3.4a Server (Debian) [192.168.178.199]
> 2013-08-27 21:06:31.085 AUTH TLS
< 2013-08-27 21:06:31.085 234 AUTH TLS successful
. 2013-08-27 21:06:31.131 TLS connect: SSLv3 read server hello A
. 2013-08-27 21:06:31.131 TLS connect: SSLv3 read server certificate A
. 2013-08-27 21:06:31.131 TLS connect: SSLv3 read server key exchange A
. 2013-08-27 21:06:31.131 TLS connect: SSLv3 read server done A
. 2013-08-27 21:06:31.131 TLS connect: SSLv3 write client key exchange A
. 2013-08-27 21:06:31.131 TLS connect: SSLv3 write change cipher spec A
. 2013-08-27 21:06:31.131 TLS connect: SSLv3 write finished A
. 2013-08-27 21:06:31.131 TLS connect: SSLv3 flush data
. 2013-08-27 21:06:31.397 TLS connect: SSLv3 read finished A
. 2013-08-27 21:06:31.397 Connection failed.
. 2013-08-27 21:06:31.397 Got reply 1004 to the command 1
* 2013-08-27 21:06:31.506 (EFatal) Connection failed.
* 2013-08-27 21:06:31.506 Connection failed.
* 2013-08-27 21:06:31.506 AUTH TLS successful
. 2013-08-27 21:06:37.668 Internal error: Connect called while still connected
. 2013-08-27 21:06:37.668 Connection failed.
. 2013-08-27 21:06:37.668 Got reply 3004 to the command 1
* 2013-08-27 21:06:37.730 (EFatal) Connection failed.
* 2013-08-27 21:06:37.730 Internal error: Connect called while still connected
* 2013-08-27 21:06:37.730 Connection failed.
TimL wrote:
Thanks for the answer! Of course I can: ...
Thanks for the log.
