Topic "WinSCP 5.1.4 crashing at the end of download."
JBM
Never had a problem at all until 5.1.4 which seems to be crashing at the end of downloading.
Level Date and Time Source Event ID Task Category
Error 26/03/13 2:52:14 AM Application Error 1000 (100) "Faulting application name: WinSCP.exe, version: 5.1.4.3020, time stamp: 0x00000000
Faulting module name: WinSCP.exe, version: 5.1.4.3020, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x0038d34d
Faulting process id: 0xdd0
Faulting application start time: 0x01ce29ea86f4f69e
Faulting application path: C:\Program Files (x86)\WinSCP\WinSCP.exe
Faulting module path: C:\Program Files (x86)\WinSCP\WinSCP.exe
Report Id: b0a78d86-95e1-11e2-bf58-bcaec576ccd2
Faulting package full name:
Faulting package-relative application ID: "
JBM
Email sent.
jhirst
Hi. I have a similar issue.
I am using 5.1.3 in our production environment.
Approximately every month WinSCP.exe faults and refuses to work via the .NET library or by running the exe.
When I bring up a new login for the production server (new RDP session) the exe works correctly.
So I have to start our software on a new RDP session which causes unwanted downtime.
Following is the dump from event viewer.
Would really appreciate a fix for this one..
Faulting application name: WinSCP.exe, version: 5.1.3.2881, time stamp: 0x00000000
Faulting module name: WinSCP.exe, version: 5.1.3.2881, time stamp: 0x00000000
Fault offset: 0x004ae79a
Faulting process id: 0x1cd0
Faulting application start time: 0x01ce6630f7bee7f0
Faulting application path: D:\Apps\WCFSelfHosted\WinSCP.exe
Faulting module path: D:\Apps\WCFSelfHosted\WinSCP.exe
Report Id: 35a0801d-d224-11e2-a835-005056a3762d
excalibur
Hi Prikryl,
I suspected below issue was similar to what i had experiencing. It happened approx. 20-30 days. Though, my method is different since I didn't use the .NET library but using scripting command by triggering winscp.com via System.Diagnostics.Process; When Winscp.exe faulted, I need to log off the current user login and re-login again or starting new RDP session.
Appreciate if you could also sent another debug version of WinSCP for me to investigate further about the issue.
Great Thanks!
I have sent you an email with a dev version of WinSCP to address you have used to register on this forum.
jhirst
Martin has suggested using a development version and this has fixed the issue. thanks!
