Command 'ls -la ' failed with return code 2
braykov
Steps to reproduce:
1) On the remote panel, go to a folder with some files where you have full access
2) Have a terminal opened and "cd" in the parent folder
3) In the terminal delete the child folder and create it again (may also "touch" some files inside)
4) In WinSCP CTRL+R to refresh the remote panel
Result:
Command 'ls -la '
failed with return code 2 and error message
. not found.
5) Click OK
Result: Nothing gets refreshed
6) repeat from 4)
Result: Nothing ever gets refreshed, but the folder is there
7) In WinSCP navigate up the path, then down
Result: It does refresh without error
Environment:
Windows 7, 32-bit; WinSCP 5.1.4; Server: AIX 6.1
WinSCP Preferences:
Environment->Panels->Remote:
  • [x] Show inaccessible directories
  • [x] Automatically refresh directory after operation
  • [ ] Refresh remote panel every
Session option for "Try to get full timestamp" is disabled.
braykov
Yes, it is SCP.
I just want to add that this appears to lead to another very nasty defect.
If I have a remote file open for editing locally, and I save it while this remote panel is showing a folder that was deleted and re-created, then transportation of the saved file back to the server fails.
Please attach a full log file showing the problem.
braykov
OK, I just sent 3 logs, for each type of logging.
I hope it helps.
When I manage to reproduce also the saving problem, I will send again.
NOTE: I tried SFTP - and no such problem.
