Topic "Set transfer mode and file characteristics"
moogeboo
I'm trying to connect via SFTP to a site that requires me to set the transfer mode and file characteristics before I upload my file. Basically, i need to issue the following command: ls /+recfm=vb,mode=text,lrecl=27000 before I issue my put command. Is this even possible to do within Winscp scripting?
Mooge
So does that mean the server abuses the SSH_FXP_READDIR to set some transfer parameters, when the "directory path" uses some special path syntax?
In that case, just use the "ls" command, exactly as in your post.
http://winscp.net/eng/docs/scriptcommand_ls
amar
Mooge
Did u finf out answer for this. Even i have the same requirement
Did you try my suggestion above?
