Topic "winscp.exe command via SSIS"
jimbo20814
Hi, when I execute a WinSCP script from via a winscp.exe command line, it works fine but doing the same via a SSIS (sql server integration services) package returns an error. In the SSIS Execute Process Task Editor I have the below settings:
Executable: C:\Program Files (x86)\WinSCP\WinSCP.exe
Arguments: /script=D:\Success_Factors\SCP_Script\JimScript.txt
Running the package returns the below:
Error: 0xC0029151 at Get files via SFTP, Execute Process Task: In Executing "C:\Program Files (x86)\WinSCP\WinSCP.exe" "/script=D:\Success_Factors\SCP_Script\JimScript.txt" at "C:\Program Files (x86)\WinSCP\", The process exit code was "1" while the expected was "0".
Task failed: Get files via SFTP
The script is the below. I've XXXX the password.
option batch off
open sftp://ecom:XXXX@sftp4.successfactors.com
cd outgoing
get JimTest.txt D:\Success_Factors\From_FTP_Server\
I'm running WinSCP 4.3.5 (build 1463) on Windows 7.
Any ideas?
Please read FAQ:
http://winscp.net/eng/docs/faq_scheduler
If that does not help, come back.
Oliphant
Suggestion : Check the FailTaskIfReturnCodeIsNotSuccessValue property of the Process in SSIS
Just set this to False. This may get you right through.
option batch off
cd outgoing
Any ideas?
Pepys
Hey jimbo20814,
Have you solved your problem and if yes how? This is really getting on my nerves now... I have tried everythhing and probably not the right solution of course...
Any help will be much appreciated Smile
Regards,
Pepys
Your question on stackoverflow.com:
http://stackoverflow.com/questions/21303885/script-file-executes-fine-but-fails-in-ssis-using-winscp
Tom G
This happened to me too and drove me crazy.
The files that I wanted were in the root directory, meaning that I didn't need (or want) WinSCP to navigate to a new directory, but it was anyway.
By default, WinSCP remembers the last directory used, and if the last directory used was the root directory, it remembers "/" as the directory used. So, the next time you attempt to connect, WinSCP attempts to find the "/" directory, which doesn't exist.
To get around this problem:
> Edit the connection
> Select 'Advanced'
> Select 'Directories' in the Advanced settings
> Deselect ‘Remember last used directory’ and remove the “/” in the Remote directory box.
It's recommended that you isolate the script run from GUI configuration:
http://winscp.net/eng/docs/scripting#configuration
