Topic "Is there a way to preserve "temporary" files?"
Travesty3
I want to keep an up-to-date local copy of any files I open from WinSCP. I will not modify the files locally, but I need to keep an up-to-date copy of them for the SourceCookifier plugin for Notepad++.
I know I can change the Temporary directory, but it still adds on the unique 'scp#####' folder at the root. I would like to be able to disable that, so that I can know the absolute path to my files.
The other thing is that WinSCP clears out the temporary files upon exiting. Is there a way to prevent that? Instead, I would want it to overwrite any existing local file when you open it from WinSCP.
Is this currently possible?
No, it is not possible.
