Topic "How to connect on remote server with option GUI"
philFrance
Hello
I would like launch WinScp with interface GUI on remote directory in a batch file.
For example
1)
Folder1.bat
winscp 192.168.0.100 remoteDirectory:/Public/folder1
2)
Folder2.bat
winscp 192.168.0.100 remoteDirectory:/Public/folder2
Thank's
Phil
philDeFrance
Hi everybody
I found the solution.
I must create a session in interface GUI and save it (for example PHIPHI ).
I declare the folder in the menu Environnement / Directory. See attached picture.
Then I launch the command in DOS (cmd )
winscp.exe PHIPHI
Description: (none)
That's one way.
If you want to do it completely from command-line, specify the remote directory as part of session URL:
http://winscp.net/eng/docs/session_url
