Topic "WinSCP 5.1.4 GSSAPI for tunnel connexion"
Hi all,
I have a problem with GSSAPI authentication.
It does work on my server directly, but it does work on my server when I use it as a tunnel.
It tells me "No supported authentication methods available (server sent: publickey, gssapi-keyex,gssapi-with-mic)."
Regards,
Swindellvc@cofc.edu
I'm running the following program based on your VBA Example
Dim sMsg As String = vbNull
Dim mySessionOptions As New WinSCP.SessionOptions
mySession.DisableVersionCheck = True
With mySessionOptions
.Protocol = Protocol.Sftp
.PortNumber = 22
.HostName = "<removed>"
.SshPrivateKeyPassphrase = "<Removed>"
.UserName = "cofc"
.SshHostKeyFingerprint = "<Removed>"
.SshPrivateKeyPath = "M:\ITExtracts\SSHKEY\myKey.ppk"
End With
' Connect
mySession.Open(mySessionOptions)
' Upload files
Dim MyTransferOptions As New WinSCP.TransferOptions
myTransferOptions.TransferMode = TransferMode.Binary
transferResult = mySession.PutFiles("M:\ITExtracts\studentlist*", "/studentlists/", False, MyTransferOptions)
' Throw on any error
transferResult.Check()
' Display results
Dim transfer As TransferEventArgs
For Each transfer In transferResult.Transfers
sMsg = "Upload of " & transfer.FileName & " succeeded"
MsgBox(sMsg, MsgBoxStyle.Information)
Next
End Sub
Error: Disconnected: No supported authentication methods available (server sent: publickey,gssapi-with mic)
How can I resolve this error
Can you login in GUI?
Swindellvc@cofc.edu
Yes...currently I'm uploading the file manually everyday
I'm trying to create a program that I have schedule to run daily
So show us session log files both from GUI and the code.
Swindellvc@cofc.edu
Where are the session logs?
Swindellvc@cofc.edu
This is the one from GUI
' Setup session options
.PortNumber = 22
.HostName = "cofc.erezlife.com"
.SshPrivateKeyPassphrase = "Removed"
.UserName = "cofc"
.SshHostKeyFingerprint = "Removed"
'.SshPrivateKeyPath = "\\aiken\ProdCognos\ITExtracts\SSHKEY\myKey.ppk"
End With
' Connect
' Upload files
'transferResult = mySession.PutFiles("\\aiken\ProdCognos\ITExtracts\studentlist.csv", "/studentlists/", False, myTransferOptions)
' Display results
Next
End Sub
cofc@cofc.erezlife.com.log (30.25 KB) Private file
Description: (none)
To generate the session log file with .NET assembly, set Session.SessionLogPath.
Swindellvc@cofc.edu
When I added this...I got a different error "Error: Error occurred during logging. It's been turned off."
This is what was added
Dim mySession As New Session
With mySession
.SessionLogPath = "C:\Development\LOGS\"
End With
Upload(mySession) <- This is the code I sent
Private Sub Upload(ByRef mySession As Session)
.PortNumber = 22
.HostName = "REMOVED"
.SshPrivateKeyPassphrase = "REMOVED"
.UserName = "cofc"
.SshHostKeyFingerprint = "REMOVED"
End With
' Connect
' Upload files
transferResult = mySession.PutFiles("M:\ITExtracts\studentlist*", "/studentlists/*.*", False, MyTransferOptions)
' Display results
Next
End Sub
Description: Error
The SessionLogPath is a path to a log file. Not a path to a directory to store a log file.
