Topic "Want to delete remote files before download via powershell"
shannra
i try your scripts to use the .netassemply by powershell. It works perfectly. Now i want to modifie it for one day, but with no success.
I want to empty the remotefolder before i upload my files.
I search here this forum and your documentations but still now, i not find a solution.
It this possible or should i use it in another way??
Are you looking for $session.RemoveFiles("/path/*") ?
http://winscp.net/eng/docs/library_session_removefiles
shannra
Thanks for you replie, but it seemed not tor work:
I use (its only snippet from the script)
    $sessionOptions.Protocol = [WinSCP.Protocol]::$protocol
    $sessionOptions.HostName = $hostname
    $sessionOptions.UserName = $username
    $sessionOptions.Password = $password
    #$sessionOptions.SshHostKeyFingerprint = "ssh-rsa 2048 9a:33:4f:9c:2b:5a:ad:ad:6b:f4:67:9f:11:51:d6:ab"
    try
        # Will continuously report progress of synchronization
        $session.add_FileTransferred( { FileTransferred } )
        # Connect
        $session.RemoveFiles("/test/*")
I get then in iSE of Powershell:
{WinSCP.SessionRemoteException: Can't get attributes of file
Please set Session.SessionLogPath and attach the log.
shannra
Its possible that i use an old version?
i only get this output, not an Logfile:
Fehler beim Aufrufen der Methode, da [WinSCP.Session] keine Methode mit dem Namen "SessionLogPath" enthlt.
in english
error by use the method because [winscp.session] no method with name "SessionLogPath"
This is hwo implement this:
try
    try
       $Session.SessionLogPath({c:\src\C:\src\Scripts\TEST\log.txt})
        # Connect
        $synchronizationResult = $session.SynchronizeDirectories(
            [WinSCP.SynchronizationMode]::Remote, $source, $target, $false)
SessionLogPath is a property, not a method. So do:
$sessionOptions.SessionLogPath = ...
See http://winscp.net/eng/docs/library_session
