Topic "Copying files from remote side failed"
LALILU
Hi Martin,
i have a little Problem with one of my FTPS-Servers.
If i try to upload or edit a file after idling a few minutes, the following error appears:
"<Empty directory listing>","Copying files from remote side failed.","Unable to build data connection: Die Operation ist nicht erlaubt"
Here a peace of the log
< 2013-04-17 17:06:16.096 227 Entering Passive Mode (???,???,???,???,197,187).
> 2013-04-17 17:06:16.096 MLSD
< 2013-04-17 17:06:16.156 150 Opening ASCII mode data connection for MLSD
. 2013-04-17 17:06:16.256 SSL connection established
< 2013-04-17 17:06:16.256 425 Unable to build data connection: Die Operation ist nicht erlaubt
. 2013-04-17 17:06:16.256 <Empty directory listing>
. 2013-04-17 17:06:16.256 Copying files from remote side failed.
* 2013-04-17 17:06:16.256 (ExtException) <Empty directory listing>
* 2013-04-17 17:06:16.256 Copying files from remote side failed.
* 2013-04-17 17:06:16.256 Unable to build data connection: Die Operation ist nicht erlaubt
. 2013-04-17 17:06:16.256 Asking user:
. 2013-04-17 17:06:16.256 Error transferring file '/htdocs/index.php'. ("<Empty directory listing>","Copying files from remote side failed.","Unable to build data connection: Die Operation ist nicht erlaubt")
* 2013-04-17 17:06:17.006 (ECommand) Copying files from remote side failed.
* 2013-04-17 17:06:17.006 Error transferring file '/htdocs/index.php'.
* 2013-04-17 17:06:17.006 <Empty directory listing>
* 2013-04-17 17:06:17.006 Copying files from remote side failed.
* 2013-04-17 17:06:17.006 Unable to build data connection: Die Operation ist nicht erlaubt
If you want the complete logfile, i can send you via gpg-email.
Armin
LALILU
Oh sorry. At the moment i am using 5.2beta but i have this problem since 5.0.7beta (wich it was the first version who realizes the connection to my ftps-server).
Please email me a complete log file. Do not encrypt it, if possible, I'm away from home with no access to my PGP key atm.
LALILU
Hi Martin,
wich logging-level i should use?
Are you at home at the moment?
Can i encrypt the logfile now?
Greets
LALILU
LALILU wrote:
Hi Martin,
Greets
Hi Martin,
can you tell me please the log-level you want?
Greets Armin
Debug 2-level please.
