Topic "is WinSCP RFC 2228 compliant?"
suzieQ
I need to write a script but requirements are that the client is RFC2228 compliant.
Is WinSCP compliant?
I cannot give yes/no answer to this. There are no required commads in RFC2228, it introduces only optional commands. So the question is, what optional functionality of RFC2228 are you required to use?
WinSCP implements these commands from RFC2228: AUTH (SSL and TLS), PROT (always P) and PBSZ (always 0).
suzieQ
I have a simple script to connect to a sftp site to grap a file.
when I manually connect via UI, it works perfect. when I test manually when in the WinSCP folder it does not connect.
I went back to the owner of the SFTP site and they said if I am scripting it needs to be RFC2228 compliant.
So how would I incorporate the commands you listed into the script?
ex of script--
option batch abort
open sftp://username:password@sftpsite.com -hostkey="ssh-rsa XXXXX"
option transfer binary
get file
close
You are connecting with SFTP protocol. RFC2228 is about Secure FTP (FTPS).
See http://winscp.net/eng/docs/ftps
So use ftps:// instead of sftp://. Also, you are probably supposed to use explicit TLS, so add -explicittls parameter. + There's no -hostkey for FTPS.
suzieQ
ok, but even before running the script I can't connect. Maybe I'm just lost here...
I navigate into the following to test---
C:\WinSCP>WinSCP.com
winscp> open
Host: sftp site
Network error: Connection timed out.
winscp>
Even when I changed the script to ftps and remove the hostkey and put -explicittls, it doesn't run.
frankly it can't even pass connecting to the site. is it b/c I'm using DOS to test?
this is what I get--
C:\WinSCP>WinSCP.com /script=script.bat
batch abort
confirm off
Connecting to sftpsite.com...
Connection failed.
Timeout detected.
Connection failed.
updated script--
option batch abort
open ftps://Username:password@sftpsite.com -explicittls
get file
close
winscp> open
Host: sftp site
winscp>
WinSCP defaults to SFTP, so here you are connecting with SFTP again.
Sorry, I cannot help you to find out what protocol/hostname or port number you are supposed to use. Please ask your server administrator.
