Topic "WinSCP Denial of Service using sftp:// and scp://"
macoo
Is there an update on work for this DoS using the registered URL types?
http://www.securiteam.com/windowsntfocus/5OP0A1FCLE.html
As work-around remove the keys
HKEY_CLASSES_ROOT\scp
and
HKEY_CLASSES_ROOT\sftp
from your registry.
macoo
I have not known about this problem. Thanks for pointing my attention to it. I'll fix this in the next version (within about week).
mornauer
With my PC WINSCP3 works normaly.
Recently I have downloaded winscp3.7.5 beta to my notebook with the same implements.
Result: "host does not exist"
What is wrong?
What is wrong?
First of all: it seems to me that this has nothing to do with the topic you follow. Am I right?
To your question: It is hard to tell. Can you try to specify IOP address instead of domain/host name?
