Topic "Error when enable feature Refresh remote panel and reconnect"
test_11223344
1 Download winscp 5.1.4, install, open.
2 Login a server via sftp.
3 Menu -> View -> Preferences, open the options menu.
4 Enviroment -> Panels -> Remote -> Remote panel -> enable "Refresh remote panel every 60s" -> OK and save.
5 Unplug the network or disable the network connection. winscp shows timeout.
6 Wait 2 minute.
7 Plug the network or enable the network connection.
8 Reconnect winscp session.
9 Error occurs.
http://winscp.net/tracker/show_bug.cgi?id=997
