Topic "Can the .NET assembly be used to make a GSSAPI Connection?"
dirk.townsend
In the GUI I can check the 'Attempt GSSAPI authentication (SSH-2)' option and make a connection using Windows Integrated Authentication (GSSAPI). On the command-line I can do the same by storing a session to the registry (or INI file). This uses the 'AuthGSSAPI' setting.
Is this also possible via the .NET assembly?
e.g. Can I connect via session information stored in the INI or registry? Or, can I specify a new connection programmatically that uses GSSAPI. I don't see a way to do this via the .NET & COM Library, but I'm not the most experienced with this API so maybe I am missing something. Rolling Eyes
Warmest Regards,
- Dirk Townsend
Please read documentation:
http://winscp.net/eng/docs/rawsettings
If that does not help, come back.
dirk.townsend
Sorry, I see it now. The SessionOptions class has an AddRawSettings method and one of the raw settings that can be added is AuthGSSAPI.
Thanks for pointing me in the right direction.
