Topic "Remote panel loses its current state"
ks
Hello.
When the remote (right) panel refreshes after executing a command in console (Ctrl-T) it loses which file focus was on and its vertical scroll position. If I refresh the panel with Ctrl-R this doesn't happen. The list of files doesn't change most of the time; and even if it does Ctrl-R works just fine.
Thanks for your post.
http://winscp.net/tracker/show_bug.cgi?id=1004
This was actually caused by fix to another bug you have reported Wink
ks
Very Happy Very Happy
Fixing bugs you should be careful!
