Topic "open directory/bookmark"
When I want to copy a folder name from Windows using the open directory/bookmark, the windows folder backslash symbol is used so on my laptop drive I have:
whereas on the server:
I am able to copy the folder name from my tools in windows but when I copy the folder path to winscp it does not understand the structure:
Prohibited file name: \public_html\components\com_jdtestimonials
I'd like to be able to copy the folder name to/from WINscp. Is there a way to make WINscp aware of Windows backslash folder style?
If not currently available I would suggest this would be a useful feature.
Sorry, I'm not sure I understand.
I understand you are running Windows on your laptop, right? So you have folder like C:\aaaa\bbbb\cccc and you want to convert that path syntax to /aaaa/bbbb/cccc, so you wan use it for remote path. Is that correct?
