Topic "WinScp Timeout Error - 5.1.5 using .net client"
mostafa.asaduzzaman@cargo
Receive the following error when I try to connect via .Net client.
Exception message: Timeout waiting for WinSCP to respond - Log file C:\WINDOWS\TEMP\wscp17A8.01E4013B.tmp was not created in time, please make sure WinSCP has write permissions to the folder
at WinSCP.Session.CheckForTimeout(String additional)
at WinSCP.Session.Open(SessionOptions sessionOptions)
CASAMostafa
Please reply my question as I am stuck at that point of error message and my web page gets hanged after giving the error message.
Ok, does your process have a write access to C:\WINDOWS\TEMP\ ?
Can you attach a complete debug log path (set Session.DebugLogPath) using WinSCP 5.2.1 beta?
CASAMostafa
How to provide write access to the process for the folder in Windows?
Regards,
Mostafa
CASAMostafa
Hi prikryl,
I have identified the IIS (6.0) process w3wp.exe is failing to write/create file in the temporary folder on the windows server. As I ran from my development machine there was no issue. The NETWORK SERVICE user has the right permission for the process. I don't know what else need to be done.
Please suggest me in this regard.
Mostafa
Sorry, I have no experience with IIS and this is really out of scope of this forum. Try asking on sftp://superuser.com. If you do, please share link to your question here.
CASAMostafa
Here is the superuser.com link
CASAMostafa
I have finally been able to run .net code for winscp access to the ftp server.
Typical uses of Winscp is to write a confirg file to the ftp folder.
What did you do to fix it? Please share it with us.
CASAMostafa
The identified problem was account mismatch between by which winscp was running and IIS pool identity account. Winscp was not picking up the pool account (Network Service) rather running with Local System account. After changing the pool identity account to Local System, it worked fine.
Thanks for sharing this.
There's FAQ covering these kind of issues:
http://winscp.net/eng/docs/faq_scheduler
Karthik
I tried the above given solution but still the issue has not been resolved.
For details on the error see
http://winscp.net/eng/docs/message_library_timeout_waiting_to_respond
