Topic "LLS command results do not appear in log files"
Snowblind1
I am using the jscript "example.js" with some modifications to upload the latest file in a directory, instead of downloading the latest file in a remote directory. However, in changing the "ls" line to show the remote directory to "lls" to show a local directory, the results are not getting listed in the log file created.
Is this normal, or am I missing something with this command?
If it is normal, is there a way to get it as part of the logging?
Snowblind1
Found the answer:
http://winscp.net/forum/viewtopic.php?t=9669
Sorry for any confusion - thanks!
