Topic "download fails after downloading only few files in SSIS"
hpjack433
there are 900 folders and the ssis package fails after downloading 61 files with the following error
[Execute Process Task] Error: In Executing "C:\Program Files (x86)\WinSCP\WinSCP.exe The process exit code was "1" while the expected was "0".
what might be the reason for that?
hpjack433
now it failed after downloading 120 folders and then it failed with the same error?
its quite random
Sorry, your post does not include enough information.
Please read how to troubleshoot problems with WinSCP. If it turns out that you are not able to help yourself, read how to ask for support or report bugs efficiently, so others can help you.
