Topic "Using filemask with exclude and timestamp"
jonleung
Hi
I'm trying to use -filemask to download files since a certain timestamp, AND exclude sub directories.
On it's own, the timestamp works fine, but it downloads qualifying files in the sub directories too:
get -filemask="*.*>2013-5-29 07:11:00" *.* .\
On its own, excluding sub directories also works fine:
get -filemask="*.*| */" *.* .\
However, when I attempt to combine the two, I get an error:
get -filemask="*.*| */>2013-5-29 07:11:00" *.* .\
Mask is invalid near '>2013-5-29 07:11:00'
I tried wrapping the filemask in double double-quotes (per this link http://winscp.net/forum/viewtopic.php?t=12192) but got errors about changing directory (see below - earlier in the script I changed to the /Downloads folder without issue)
> 2013-05-29 11:37:19.740 Script: get -filemask=""*.*| */>2013-5-29 07:11:00"" *.* .\
. 2013-05-29 11:37:19.740 Retrieving directory listing...
> 2013-05-29 11:37:19.740 CWD /Downloads/*/
< 2013-05-29 11:37:19.762 550 Can't change directory to /Downloads/*/: No such file or directory
Any suggestions?
You were almost there:
get -filemask="*.*>2013-5-29 07:11:00| */" *.* .\
It's include_mask|exclude_mask and time constraint is part of the include_mask:
http://winscp.net/eng/docs/file_mask
jonleung
This works - thank you so much, Martin!
