Accepts 'Any' SSH Hostkey
Re: Accepts 'Any' SSH Hostkey
In the latest beta version you can use -hostkey=* switch of open command.
You are giving up any security by doing this though. Make sure you understand the implications.
Ramesh
-hostkey=* - does not work on winscp 4.2.9
Hi
I use this command line to transfer files
Requirement is tranfer single file from windows to multiple AIX boxes :
c:\winscp429\winscp.com /command "option confirm off" "open sftp://username:password@boxname -hostkey=*" "put c:\t1.txt /tmp/t3.txt" "close" "exit"
it works, but askes for hostkey addition to cache everytime, can u help pls, am struggleing and it is already 4 hrs i spent on this.
