Topic "managing frequent hostkey changes"
foodieguy
Hi all,
I have a vendor that uses some kind of load balancer or hosted server solution and they frequently change servers/hostkeys with no notice. So my script breaks.
Is there a way to automate acceptance of the new hostkeys with no intervention? I use the -hostkey switch,
-hostkey="ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
but it's not clear if you have to specify each hostkey. I'd like to accept whatever hostkey they give us, as we get them. Am I stuck with reacting to these unexpected changes each time?
If it helps, I use the winscp.exe and am on version 4.3.5
thx!
If there's a set of servers (load balanced), the best solution is to list all hostkeys in the script (semicolon separated in the -hostkey switch).
If you cannot get list of all hostkeys, you can use -hostkey=* with the latest beta version. But you give up any security by doing this. Make sure you understand the implications.
You should upgrade in any case.
