Topic "Tyring to create automatic download with Scheduled Task"
Zietzevliege
Currently i'm trying to create a situation where we can run an Scheduled Task in Windows Server 2008 R2, which automatic downloads a set of files from the WINCSP.
I tried to do it with a command prompt, and from there i can open an connection to WINCSp via FTPS. This is the command i used:
winscp.exe ftps://username:password@ftpaddress:21 -passive -explicitssl -explicittls -certificate="xx:xx:xx"
Connection is established. But no i want it to download certain *.csv files from this FTPS connection. I tried to use the GET command, but this will not do anything:
winscp.exe ftps://username:password@ftpaddress:21 -passive -explicitssl -explicittls -certificate="xx:xx:xx" winscp.com /command "get abcd.csv C:\Download\"
winscp.exe ftps://username:password@ftpaddress:21 -passive -explicitssl -explicittls -certificate="xx:xx:xx" get abcd.csv C:\Download\
Is there something i'm doing wrong? Perhaps anybody knows the right way to use it.
Many thanks in advance.
You have it all wrong.
Please start from a scratch. Follow this guide:
http://winscp.net/eng/docs/guide_automation
