Topic "SFTP on Win 7 64 bit, no go"
Tony Thijs
I tried to install winscp on Win 7 64 bit. It seems that WINSCP is not compatible. Is there a solution for this?
Kind regards,
Tony Thijs
Brogue2
I have WinSCP version 5.2.1 installed on Windows 7 (64 bit). No problems here connecting to and managing files on an SFTP server.
Can you describe your problem in greater detail? What exactly isn't working as you expected.
WinSCP runs fine on Windows 7 64bit.
What makes you believe it's not compatible? Any error message?
