Topic "Find File lists every directory"
pinkyinbrain
Hello
I try to find specific files throug the "find file" function.
The Problem is, that every search i try all the directories are in the list of results.
I allready tested if i look for one specific file, for example abc.txt and i know this file only exists once, there are still all directories shown in the result list.
What am i doing wrong?
Thanks in advence!!!
What version of WinSCP are you using? There was such an error in releases prior to 5.1.4. Make sure you have the latest version installed.
