Topic "WinSCP 5.2.1 Network error: Software caused connection abort"
hansolo
Hello.
I'm using WinSCP 5.2.1 (build 3231) on Windows 7 SP1 Ultimate.
I have try to upload a zip archive on FTP of my hosting provider with SCP or SFTP connection and after about 98-107 Mb of transfering I always get this error: Network error: Software caused connection abort. In case that I'm using the WinSCP 5.1.5 before same trouble.
But when I enabled a compression the file were uploaded fine but with 2 times slower of speed bandwidth. On simple FTP connection without secure it's works ok.
Then I try to upload this file with FileZilla 3.0.7.2 all done with no errors and without compression.
. 2013-06-18 06:44:15.714 [Background 1] Startup conversation with host finished.
. 2013-06-18 06:44:15.715 [Background 1] Copying 1 files/directories to remote directory "/home/a/aleks/"
. 2013-06-18 06:44:15.715 [Background 1] PrTime: Yes; PrRO: No; Rght: rwx------; PrR: No (Yes); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2013-06-18 06:44:15.715 [Background 1] TM: M; ClAr: No; CPS: 0; NewerOnly: No; InclM:
. 2013-06-18 06:44:15.715 [Background 1] AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml; *.less
> 2013-06-18 06:44:15.715 [Background 1] echo "WinSCP: this is begin-of-file" ; scp -r -d -t "/home/a/aleks" ; echo "WinSCP: this is end-of-file:$?"
< 2013-06-18 06:44:15.778 [Background 1] WinSCP: this is begin-of-file
. 2013-06-18 06:44:15.779 [Background 1] SCP remote side confirmation (0)
. 2013-06-18 06:44:15.779 [Background 1] File: "E:\_bkp\aleks\al.zip"
. 2013-06-18 06:44:15.780 [Background 1] Copying "E:\_bkp\aleks\al.zip" to remote directory started.
. 2013-06-18 06:44:15.780 [Background 1] Binary transfer mode selected.
> 2013-06-18 06:44:15.781 [Background 1] T1371458537 0 1371458442 0
. 2013-06-18 06:44:15.847 [Background 1] SCP remote side confirmation (0)
> 2013-06-18 06:44:15.847 [Background 1] C0700 193092033 al.zip
. 2013-06-18 06:44:15.911 [Background 1] SCP remote side confirmation (0)
. 2013-06-18 06:44:15.911 [Background 1] Sending BINARY data (first block, 4096 bytes)
. 2013-06-18 06:44:39.140 Sending null packet to keep session alive.
. 2013-06-18 06:44:39.140 Sending special code: 15
. 2013-06-18 06:44:40.784 [Background 1] Network error: Software caused connection abort
. 2013-06-18 06:44:40.784 [Background 1] Asking user:
. 2013-06-18 06:44:40.784 [Background 1] Network error: Software caused connection abort ("Copying file 'E:\_bkp\aleks\al.zip' fatally failed.","Copying files to remote side failed.")
. 2013-06-18 06:45:01.971 Getting current directory name.
> 2013-06-18 06:45:01.971 pwd ; echo "WinSCP: this is end-of-file:$?"
< 2013-06-18 06:45:01.998 /home/a/aleks
< 2013-06-18 06:45:01.998 WinSCP: this is end-of-file:0
