Topic "Support reuest - error whn uploading files"
Anat
Hi, We have a script that uploads hourly files to a remote FTP.
Every now and then the script fails with this error.
We use version 5.1.1.2735 over win 2007.
What could be the reason? Attached here is the log.
Anat
. 2013-06-23 07:11:18.463 --------------------------------------------------------------------------
. 2013-06-23 07:11:18.463 Using FTP protocol.
. 2013-06-23 07:11:18.463 Doing startup conversation with host.
> 2013-06-23 07:11:18.463 PWD
< 2013-06-23 07:11:18.572 257 "/"
. 2013-06-23 07:11:18.572 Getting current directory name.
. 2013-06-23 07:11:18.572 Startup conversation with host finished.
< 2013-06-23 07:11:18.572 Script: Active session: [1] bla@ftp.bla.net
> 2013-06-23 07:11:18.572 Script: put \\server\folder\file.gz file.gz
. 2013-06-23 07:11:18.635 Copying 1 files/directories to remote directory "/"
. 2013-06-23 07:11:18.635 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask: file.gz
. 2013-06-23 07:11:18.635 TM: B; ClAr: No; CPS: 0; InclM:
. 2013-06-23 07:11:18.635 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2013-06-23 07:11:18.635 File: "\\server\folder\file.gz"
. 2013-06-23 07:11:18.635 Copying "\\server\folder\file.gz" to remote directory started.
. 2013-06-23 07:11:18.635 Binary transfer mode selected.
. 2013-06-23 07:11:18.635 Starting upload of \\server\folder\file.gz
> 2013-06-23 07:11:18.635 TYPE A
< 2013-06-23 07:11:18.775 200 Switching to ASCII mode.
> 2013-06-23 07:11:18.775 PASV
< 2013-06-23 07:11:18.900 227 Entering Passive Mode (10,20,19,66,141,37).
. 2013-06-23 07:11:18.900 Server sent passive reply with unroutable address 1.2.3.4, using host address instead.
> 2013-06-23 07:11:18.900 LIST
< 2013-06-23 07:11:19.119 150 Here comes the directory listing.
. 2013-06-23 07:11:19.119 SSL connection established
. 2013-06-23 07:11:19.994 Copying files to remote side failed.
< 2013-06-23 07:11:20.275 226 Directory send OK.
* 2013-06-23 07:11:20.275 (ExtException) Server sent passive reply with unroutable address 1.2.3.4, using host address instead.
* 2013-06-23 07:11:20.275 Copying files to remote side failed.
* 2013-06-23 07:11:20.275 Directory send OK.
. 2013-06-23 07:11:20.275 Asking user:
. 2013-06-23 07:11:20.275 Error transferring file '\\server\folder\file.gz'. ("Server sent passive reply with unroutable address 1.2.3.4, using host address instead.","Copying files to remote side failed.","Directory send OK.")
< 2013-06-23 07:11:20.275 Script: Error transferring file '\\server\folder\file.gz'.
< 2013-06-23 07:11:20.275 Script: Server sent passive reply with unroutable address 1.2.3.4, using host address instead.
< 2013-06-23 07:11:20.275 Copying files to remote side failed.
< 2013-06-23 07:11:20.275 Directory send OK.
* 2013-06-23 07:11:20.275 (EScpSkipFile) Error transferring file '\\server\folder\file.gz'.
* 2013-06-23 07:11:20.275 Server sent passive reply with unroutable address 1.2.3.4, using host address instead.
. 2013-06-23 07:11:20.275 Script: Failed
> 2013-06-23 07:11:20.275 Script: exit
. 2013-06-23 07:11:20.275 Script: Exit code: 1
. 2013-06-23 07:11:20.275 Disconnected from server
