Topic "WinSCP.com and whitespaces"
nerys64
if there is a whitespace in the file name, winscp.com stops reading after the white space. Using double and single quotes does not fix this behavior. Using full path instead of relative path does not fix this behavior.
C:\Users\shrimants\TEST>dir /s /b
C:\Users\shrimants\TEST\batch.bat
C:\Users\shrimants\TEST\filelist.tmp
C:\Users\shrimants\TEST\testscript (1).txt
C:\Users\shrimants\TEST\testscript (2).txt
C:\Users\shrimants\TEST\testscript (3).txt
C:\Users\shrimants\TEST\testscript (4).txt
C:\Users\shrimants\TEST\testscript (5).txt
C:\Users\shrimants\TEST\testscript (6).txt
C:\Users\shrimants\TEST\testscript.winscp
C:\Users\shrimants\TEST>"c:\Program Files (x86)\WinSCP\WinSCP.com" /script=tests
cript.winscp /parameter 'testscript (1).txt'
batch           abort
confirm         off
Searching for host...
Connecting to host...
Authenticating...
Using username "shrimant".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] shrimant@login.umd.umich.edu
/home/user/s/h/shrimant/TEST
transfer        binary
File or folder ''testscript' does not exist.
System Error.  Code: 2.
The system cannot find the file specified
cript.winscp /parameter "testscript (1).txt"
batch           abort
confirm         off
Authenticating...
Authenticated.
Session started.
transfer        binary
File or folder 'testscript' does not exist.
1) Use double-quotes, not single-quotes.
2) Make sure you surround the %1% with double-quotes too. See:
http://winscp.net/eng/docs/scripting#syntax
