Topic "No such file or directory error"
JohnBK
I am getting this error. Not sure why. Any help would be Greatly appreciated. Posting log below. Thanks!
. 2013-07-03 15:56:27.620 --------------------------------------------------------------------------
. 2013-07-03 15:56:27.620 WinSCP Version 5.1.4 (Build 3020) (OS 6.1.7601 Service Pack 1)
. 2013-07-03 15:56:27.620 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2013-07-03 15:56:27.620 Local account: HANOVERGOV\itelp
. 2013-07-03 15:56:27.620 Working directory: C:\Program Files\WinSCP
. 2013-07-03 15:56:27.620 Command-line: "C:\Program Files\WinSCP\WinSCP.exe"
. 2013-07-03 15:56:27.620 Time zone: Current: GMT-4, Standard: GMT-5, DST: GMT-4, DST Start: 3/10/2013, DST End: 11/3/2013
. 2013-07-03 15:56:27.620 Login time: Wednesday, July 03, 2013 3:56:27 PM
. 2013-07-03 15:56:27.620 Session name: J460@173.203.25.180 (Ad-Hoc session)
. 2013-07-03 15:56:27.620 Host name: 173.203.25.180 (Port: 22)
. 2013-07-03 15:56:27.620 User name: J460 (Password: No, Key file: No)
. 2013-07-03 15:56:27.620 Tunnel: No
. 2013-07-03 15:56:27.620 Transfer Protocol: SFTP (SCP)
. 2013-07-03 15:56:27.620 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2013-07-03 15:56:27.620 Proxy: none
. 2013-07-03 15:56:27.620 SSH protocol version: 2; Compression: No
. 2013-07-03 15:56:27.620 Bypass authentication: No
. 2013-07-03 15:56:27.620 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2013-07-03 15:56:27.620 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2013-07-03 15:56:27.620 SSH Bugs: A,A,A,A,A,A,A,A,A,A
. 2013-07-03 15:56:27.620 SFTP Bugs: A,A
. 2013-07-03 15:56:27.620 Return code variable: Autodetect; Lookup user groups: A
. 2013-07-03 15:56:27.620 Shell: default
. 2013-07-03 15:56:27.620 EOL: 0, UTF: 2
. 2013-07-03 15:56:27.620 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2013-07-03 15:56:27.620 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2013-07-03 15:56:27.620 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2013-07-03 15:56:27.620 Cache directory changes: Yes, Permanent: Yes
. 2013-07-03 15:56:27.620 DST mode: 1; Timezone offset: 0h 0m
. 2013-07-03 15:56:27.729 Looking up host "173.203.25.180"
. 2013-07-03 15:56:27.729 Connecting to 173.203.25.180 port 22
. 2013-07-03 15:56:28.088 Server version: SSH-2.0-1.82_sshlib GlobalSCAPE
. 2013-07-03 15:56:28.088 Using SSH protocol version 2
. 2013-07-03 15:56:28.088 We claim version: SSH-2.0-WinSCP_release_5.1.4
. 2013-07-03 15:56:28.291 Doing Diffie-Hellman group exchange
. 2013-07-03 15:56:28.853 Doing Diffie-Hellman key exchange with hash SHA-1
. 2013-07-03 15:56:29.211 Verifying host key rsa2 0x11,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 with fingerprint ssh-rsa 2048 59:54:c2:07:b1:98:5c:b4:eb:62:4a:03:e8:3d:dd:27
. 2013-07-03 15:56:29.227 Host key matches cached key
. 2013-07-03 15:56:29.227 Host key fingerprint is:
. 2013-07-03 15:56:29.227 ssh-rsa 2048 59:54:c2:07:b1:98:5c:b4:eb:62:4a:03:e8:3d:dd:27
. 2013-07-03 15:56:29.227 Initialised AES-256 CBC client->server encryption
. 2013-07-03 15:56:29.227 Initialised HMAC-SHA1 client->server MAC algorithm
. 2013-07-03 15:56:29.227 Initialised AES-256 CBC server->client encryption
. 2013-07-03 15:56:29.227 Initialised HMAC-SHA1 server->client MAC algorithm
! 2013-07-03 15:56:29.570 Using username "J460".
. 2013-07-03 15:56:33.189 Attempting keyboard-interactive authentication
. 2013-07-03 15:56:33.361 Prompt (6, SSH server authentication, Using keyboard-interactive authentication., Enter password: )
. 2013-07-03 15:56:37.901 Access granted
. 2013-07-03 15:56:38.150 Opened channel for session
. 2013-07-03 15:56:38.883 Started a shell/command
. 2013-07-03 15:56:38.930 --------------------------------------------------------------------------
. 2013-07-03 15:56:38.930 Using SFTP protocol.
. 2013-07-03 15:56:38.930 Doing startup conversation with host.
> 2013-07-03 15:56:38.993 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2013-07-03 15:56:39.133 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2013-07-03 15:56:39.133 SFTP version 3 negotiated.
. 2013-07-03 15:56:39.133 We believe the server has signed timestamps bug
. 2013-07-03 15:56:39.133 We will use UTF-8 strings for status messages only
. 2013-07-03 15:56:39.180 Getting current directory name.
. 2013-07-03 15:56:39.180 Getting real path for '.'
> 2013-07-03 15:56:39.180 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2013-07-03 15:56:39.289 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2013-07-03 15:56:39.289 Real path is '/'
. 2013-07-03 15:56:39.429 Listing directory "/".
> 2013-07-03 15:56:39.429 Type: SSH_FXP_OPENDIR, Size: 10, Number: 267
< 2013-07-03 15:56:39.523 Type: SSH_FXP_HANDLE, Size: 10, Number: 267
> 2013-07-03 15:56:39.523 Type: SSH_FXP_READDIR, Size: 10, Number: 524
< 2013-07-03 15:56:39.632 Type: SSH_FXP_NAME, Size: 179, Number: 524
> 2013-07-03 15:56:39.632 Type: SSH_FXP_READDIR, Size: 10, Number: 780
< 2013-07-03 15:56:39.741 Type: SSH_FXP_STATUS, Size: 22, Number: 780
< 2013-07-03 15:56:39.741 Status code: 1
> 2013-07-03 15:56:39.741 Type: SSH_FXP_CLOSE, Size: 10, Number: 1028
. 2013-07-03 15:56:39.866 Startup conversation with host finished.
. 2013-07-03 15:57:01.535 Cached directory change via "From" to "/From".
. 2013-07-03 15:57:01.535 Getting current directory name.
. 2013-07-03 15:57:01.535 Listing directory "/From".
> 2013-07-03 15:57:01.535 Type: SSH_FXP_OPENDIR, Size: 14, Number: 1291
< 2013-07-03 15:57:01.535 Type: SSH_FXP_STATUS, Size: 21, Number: 1028
. 2013-07-03 15:57:01.535 Discarding reserved response
< 2013-07-03 15:57:01.659 Type: SSH_FXP_HANDLE, Size: 10, Number: 1291
> 2013-07-03 15:57:01.659 Type: SSH_FXP_READDIR, Size: 10, Number: 1548
< 2013-07-03 15:57:01.862 Type: SSH_FXP_STATUS, Size: 22, Number: 1548
< 2013-07-03 15:57:01.862 Status code: 1
. 2013-07-03 15:57:01.862 Listing file "/From/..".
> 2013-07-03 15:57:01.862 Type: SSH_FXP_LSTAT, Size: 17, Number: 1799
< 2013-07-03 15:57:01.956 Type: SSH_FXP_ATTRS, Size: 21, Number: 1799
. 2013-07-03 15:57:01.956 ..;D;0;2013-04-14T19:36:48.000Z;"" [0];"" [0];rwxrw-rw-;1
> 2013-07-03 15:57:01.956 Type: SSH_FXP_CLOSE, Size: 10, Number: 2052
. 2013-07-03 15:57:07.353 Copying 1 files/directories to remote directory "/From/"
. 2013-07-03 15:57:07.353 PrTime: No; PrRO: No; Rght: rw-r--r--; PrR: Yes (Yes); FnCs: N; RIC: 0100; Resume: N (102400); CalcS: Yes; Mask: *.*
. 2013-07-03 15:57:07.353 TM: B; ClAr: No; CPS: 0; InclM:
. 2013-07-03 15:57:07.353 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2013-07-03 15:57:07.353 File: "C:\NWS\VA130702.TXT"
. 2013-07-03 15:57:07.369 Copying "C:\NWS\VA130702.TXT" to remote directory started.
. 2013-07-03 15:57:07.369 Binary transfer mode selected.
. 2013-07-03 15:57:07.369 Opening remote file.
> 2013-07-03 15:57:07.369 Type: SSH_FXP_OPEN, Size: 43, Number: 2307
< 2013-07-03 15:57:07.369 Type: SSH_FXP_STATUS, Size: 21, Number: 2052
. 2013-07-03 15:57:07.369 Discarding reserved response
< 2013-07-03 15:57:07.697 Type: SSH_FXP_STATUS, Size: 33, Number: 2307
< 2013-07-03 15:57:07.697 Status code: 2, Message: 2307, Server: File not found, Language: en
> 2013-07-03 15:57:07.697 Type: SSH_FXP_LSTAT, Size: 27, Number: 2567
< 2013-07-03 15:57:08.087 Type: SSH_FXP_STATUS, Size: 33, Number: 2567
< 2013-07-03 15:57:08.087 Status code: 2, Message: 2567, Server: File not found, Language: en
* 2013-07-03 15:57:08.087 (ETerminal) No such file or directory.
* 2013-07-03 15:57:08.087 Error code: 2
* 2013-07-03 15:57:08.087 Error message from server (en): File not found
* 2013-07-03 15:57:08.087 Request code: 3
. 2013-07-03 15:57:08.087 Asking user:
. 2013-07-03 15:57:08.087 Cannot create remote file '/From/VA130702.TXT'. ("No such file or directory.
. 2013-07-03 15:57:08.087 Error code: 2
. 2013-07-03 15:57:08.087 Error message from server (en): File not found
. 2013-07-03 15:57:08.087 Request code: 3")
* 2013-07-03 15:57:14.576 (EScpSkipFile) Cannot create remote file '/From/VA130702.TXT'.
* 2013-07-03 15:57:14.576 No such file or directory.
* 2013-07-03 15:57:14.576 Error code: 2
* 2013-07-03 15:57:14.576 Error message from server (en): File not found
* 2013-07-03 15:57:14.576 Request code: 3
. 2013-07-03 15:57:14.576 Listing directory "/From".
> 2013-07-03 15:57:14.576 Type: SSH_FXP_OPENDIR, Size: 14, Number: 2827
< 2013-07-03 15:57:14.685 Type: SSH_FXP_HANDLE, Size: 10, Number: 2827
> 2013-07-03 15:57:14.685 Type: SSH_FXP_READDIR, Size: 10, Number: 3084
< 2013-07-03 15:57:14.826 Type: SSH_FXP_STATUS, Size: 22, Number: 3084
< 2013-07-03 15:57:14.826 Status code: 1
. 2013-07-03 15:57:14.826 Listing file "/From/..".
> 2013-07-03 15:57:14.826 Type: SSH_FXP_LSTAT, Size: 17, Number: 3335
< 2013-07-03 15:57:15.013 Type: SSH_FXP_ATTRS, Size: 21, Number: 3335
. 2013-07-03 15:57:15.013 ..;D;0;2013-04-14T19:36:48.000Z;"" [0];"" [0];rwxrw-rw-;1
> 2013-07-03 15:57:15.013 Type: SSH_FXP_CLOSE, Size: 10, Number: 3588
. 2013-07-03 15:58:25.033 Copying 1 files/directories to remote directory "/From/"
. 2013-07-03 15:58:25.033 PrTime: No; PrRO: No; Rght: rw-r--r--; PrR: Yes (Yes); FnCs: N; RIC: 0100; Resume: N (102400); CalcS: Yes; Mask: *.*
. 2013-07-03 15:58:25.033 TM: B; ClAr: No; CPS: 0; InclM:
. 2013-07-03 15:58:25.033 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2013-07-03 15:58:25.033 File: "C:\NWS\VA130702.TXT"
. 2013-07-03 15:58:25.033 Copying "C:\NWS\VA130702.TXT" to remote directory started.
. 2013-07-03 15:58:25.033 Binary transfer mode selected.
. 2013-07-03 15:58:25.033 Opening remote file.
> 2013-07-03 15:58:25.033 Type: SSH_FXP_OPEN, Size: 43, Number: 3843
< 2013-07-03 15:58:25.033 Type: SSH_FXP_STATUS, Size: 21, Number: 3588
. 2013-07-03 15:58:25.033 Discarding reserved response
< 2013-07-03 15:58:25.844 Type: SSH_FXP_STATUS, Size: 33, Number: 3843
< 2013-07-03 15:58:25.844 Status code: 2, Message: 3843, Server: File not found, Language: en
> 2013-07-03 15:58:25.844 Type: SSH_FXP_LSTAT, Size: 27, Number: 4103
< 2013-07-03 15:58:26.795 Type: SSH_FXP_STATUS, Size: 33, Number: 4103
< 2013-07-03 15:58:26.795 Status code: 2, Message: 4103, Server: File not found, Language: en
* 2013-07-03 15:58:26.795 (ETerminal) No such file or directory.
* 2013-07-03 15:58:26.795 Error code: 2
* 2013-07-03 15:58:26.795 Error message from server (en): File not found
* 2013-07-03 15:58:26.795 Request code: 3
. 2013-07-03 15:58:26.795 Asking user:
. 2013-07-03 15:58:26.795 Cannot create remote file '/From/VA130702.TXT'. ("No such file or directory.
. 2013-07-03 15:58:26.795 Error code: 2
. 2013-07-03 15:58:26.795 Error message from server (en): File not found
. 2013-07-03 15:58:26.795 Request code: 3")
* 2013-07-03 15:58:29.401 (EScpSkipFile) Cannot create remote file '/From/VA130702.TXT'.
* 2013-07-03 15:58:29.401 No such file or directory.
* 2013-07-03 15:58:29.401 Error code: 2
* 2013-07-03 15:58:29.401 Error message from server (en): File not found
* 2013-07-03 15:58:29.401 Request code: 3
. 2013-07-03 15:58:29.401 Listing directory "/From".
> 2013-07-03 15:58:29.401 Type: SSH_FXP_OPENDIR, Size: 14, Number: 4363
< 2013-07-03 15:58:29.775 Type: SSH_FXP_HANDLE, Size: 10, Number: 4363
> 2013-07-03 15:58:29.775 Type: SSH_FXP_READDIR, Size: 10, Number: 4620
< 2013-07-03 15:58:30.134 Type: SSH_FXP_STATUS, Size: 22, Number: 4620
< 2013-07-03 15:58:30.134 Status code: 1
. 2013-07-03 15:58:30.134 Listing file "/From/..".
> 2013-07-03 15:58:30.134 Type: SSH_FXP_LSTAT, Size: 17, Number: 4871
< 2013-07-03 15:58:30.446 Type: SSH_FXP_ATTRS, Size: 21, Number: 4871
. 2013-07-03 15:58:30.446 ..;D;0;2013-04-14T19:36:48.000Z;"" [0];"" [0];rwxrw-rw-;1
> 2013-07-03 15:58:30.446 Type: SSH_FXP_CLOSE, Size: 10, Number: 5124
. 2013-07-03 15:58:36.046 Closing connection.
. 2013-07-03 15:58:36.046 Sending special code: 12
. 2013-07-03 15:58:36.046 Sent EOF message
Can you attach a session log file using the latest version of WinSCP?
