Topic "Can't connect to server with accents in password"
ptreille
Hello to all
I am here to report a bug in WinSCP (actual tested : 5.1.4, Build 3020) in connection to linux server (Debian 6 & Debian 7 tested) in SFTP. (Client tested on Windows XP SP3 32bits, Windows 7 64bits, Windows 8 64bits). in GUI mode Commander
Since we have add an accent in the password in UTF8 format, we can't no more connect to server with this user.
We have tested with removed accent, it work, but not with accent (and we can't specify the format we want to use to send authentification, can be the problem ?)
Error is simple : "accs refus" (access denied i suppose in english) in log window
Thank you to all to have a look on it, and for your support
ptreille@imdeveloppement.com
Thanks for your post.
http://winscp.net/tracker/show_bug.cgi?id=1014
Note that it work under Putty ; we can choice the format we want to use to send (UTF8, in Window/Translation menu of Putty)
Thank you for your support
ptreille
Sorry for 'Guest'. It's still me.
I said that just because in your bug track, it write : in wishlist of putty (this wish is certainly close now)
It's not. See the link in tracker.
