Topic "Rename File - Overwrite Existing"
Yellow
Hi
In .net is it possible to rename a file and if that file already exists, overwrite it automatically?
Cheers
So you want Session.MoveFile to remove target file, if that already exists, correct? It's not possible, unless the server does it for you, what it usually does not.
Why don't you use Session.FileExists and Session.RemoveFiles first?
http://winscp.net/eng/docs/library_session_fileexists
http://winscp.net/eng/docs/library_session_removefiles
Yellow
Hi
Thanks for the reply. Basically I want to upload a file name 'MyFile'. Then rename it to 'MyNewFile'. If 'MyNewFile' already exists, then have an option to overwrite the existing 'MyNewFile'.
I realise I can delete the existing file first, that's not a problem. But I found this thread, which suggests such a rename feature exists, unless I am not understanding it: http://winscp.net/forum/viewtopic.php?t=25
Cheers
That's for GUI only.
Yellow
No worries. Thanks for letting me know.
