Topic "background transfer"
yueluo
I really like the new background transfer feature in 3.6.0, but I have a few questions.
1) If I do not turn on confirmation for drag & drop, then when I drag and drop WinSCP automatically uses foreground transfer. Is there a way to turn on background transfer as default for all transfers?
2) I tried to turn on "use same setting next time" and "transfer on background" on the copy confirmation window, but still background transfer is not automatically used for the next time. I have to select background transfer again.
3) When I use background transfer, the program ask for password for each background transfer. This is unnecessary. The program could store the login password for later use in background.
4) What is the option "Automatically popup prompts of background transfers when idle" in the Preference|Transfer|Background panel?
5) What is the "no confirmation" in the copy confirmation window?
Thank you for the new background feature. Hope it will become better in the next version.
yue
Not yet. I may add it.
"Use same settings next time" does not apply to "Transfer on background". That's why it is above it.
I wanted to avoid having password in memory. Of course you may save your password to stored session. It will be used by background transfers as well.
As workaround, you may also load your stored session (without password) and enter password directly on login dialog, instead of password dialog during connection.
When turned on and background transfer needs your attention (error message, query, password prompt, etc), the window will popup. If you turn it off, it won't, just a flashing icon will be displayed next to transfer on queue list. You will need to double click it to show the prompt. I believe that it is useful when you have plenty of background transfers. Then it may be diffucult to distinguish what transfer does the prompt belong to, if it pops up automatically.
It is basically to supress overwrite confirmations. The same as with Synchronize function.
Thanks for your answer. Your designs for my question 4 and 5 are very good. I just did not understand it. Now it makes good sense.
It would be nice if you could add an option to turn on background transfer as default.
Store password in memory is not a big security risk. I would rather take this "risk" than inputing password for every background transfer. At least give the option to take this risk. Smile
Thank you.
yue
I did already, please wait for the next release.
OK, I'll consider that.
Desummoner
As for me, very comfortable solution is to use Pageant (PuTTY authentication agent). But, this one also keeps something in memory.
