Topic "Upload File - Append To Existing File"
Yellow
Hi
Is it possible to upload MyFile.txt to a server and if the file exists on the FTP server, append the content of the local file to the existing file on the FTP server?
Cheers
This is not supported with .NET assembly yet. But you can easily add it as the assembly is open source.
See similar example:
http://winscp.net/forum/viewtopic.php?t=12452
Yellow
That's great, thanks very much.
JeffClay
You could always use winscp.net to see if the file exists, if it does then download it locally and use streamwriter or something to append the text and put the file back on the server.
