Topic "WinSCP and busybox reboot command"
wlarsong
Using WinSCP to upload a file then reboot the device
C:\Program Files\WinSCP>WinSCP.com /privatekey=C:\Users\willl\Desktop\synergy-ss
h2.ppk /nointeractiveinput /command "option batch abort" "option confirm off" "o
pen ""scp://dropbear@192.168.1.110:/Arm/Synergy/" "call /Arm/busybox1.19 killall
init.sh 2>&1" "put ""C:\Users\willl\Desktop\SynergyDemo" "call /Arm/busybox1.19
reboot -nfd 10 2>&1" "close" "exit"
When I run the "call /Arm/busybox1.19 reboot -nfd 10 2>&1"
It doesn't then close the connection with the "close" it instead waits and then I get the
Host is not communicating for more than 15 seconds. Still waiting...
Note: If the problem repeats, try turning off 'Optimize connection buffer size'.
Warning: Aborting this operation will close connection!
(A)bort (0 s): Abort
Two Questions
1) If i have the option batch abort option confirm off and /nointeractiveinput why and I getting this message shouldn't it just abort the connection
2) How can I run the /Arm/busybox reboot call without waiting for confirmation
It looks like the connection is not properly closed, because WinSCP does seem to detect that the server went down. Can you please try the same using 5.2.2 beta and attach a complete session log?
Because timeout is not an irrecoverable error (I understand that it is, in your case). That's why there's another 60 seconds interval (by default).
wlarsong
Attached is the session log with beta version 5.2.1 I could not find 5.2.2 (is it a drunk build?)
Still the same result. Can you run a command a "call" without waiting for a response or forcing a return. I know that linux can with the | command.
synergy-session.log (21.29 KB) [Download]
Description: (none)
You may try to run the reboot on background (add & at the end of the command). Anyway, I would still like to try the debug version.
wlarsong
Tried that:
h2.ppk /command "option batch abort" "option confirm off" "open ""scp://dropbear
@192.168.1.110:/Arm/Synergy/" "put ""C:\Users\willl\Desktop\SynergyDemo" "call /
Arm/busybox1.19 reboot -nfd 5&" "close" "exit"
batch abort
confirm off
Searching for host...
Connecting to host...
Authenticating...
Using username "dropbear".
Authenticating with public key "imported-openssh-key".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] dropbear@192.168.1.110
C:\...\SynergyDemo | 2694 KiB | 131.9 KiB/s | binary | 100%
Syntax error: ";" unexpected
Connection has been unexpectedly closed. Server sent command exit status 2.
Session 'dropbear@192.168.1.110' closed.
No session.
Something about a semicolon. The device doesn't complete the reboot if I add the &
