Topic "Unattended Install - No Update check"
mygwl
Hi there,
I've an issue with unattended installation of WinSCP 5.1.5.
I use the cmd winscp515setup.exe /SAVEINF="conf.inf" to generate a configuration file.
During the manual setup process, I disable auto updates :
http://s23.postimg.org/iuktarvzb/settings.png
Then I use the following script for silent installation :
"%~dp0winscp515setup.exe"  /VERYSILENT /NORESTART /LOADINF="%~dp0conf.inf" /NOCANDY /LOG="C:\install\Logs\winscp.txt"
The program is deployed to end users with Miscrofot SCCM 2007.
When I check the settings on users computers, the auto update setting is not disabled :
http://s13.postimg.org/yd561n97n/ui_pref.png
I checked in the registry, in noticed that there are keys related to updates settings in [HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Updates]
but I don't get how to set the value of the keys to disable autou pdates.
How can I fix that ?
How can I disable updates check, and check for beta version for all users when installing ?
Thanks in advance,
Yours faithfully, mygwl
Thanks for your post.
This issue is being tracked already:
http://winscp.net/tracker/show_bug.cgi?id=758
Meanwhile, you can turn off the update check by setting following registry key:
"Period"=dword:00000000
Kreezer
prikryl wrote:
Sorry, but HKEY_CURRENT_USER isn't for all users.
You have to change the program to read HKEY_LOCAL_MACHINE, so it's global for all users.
You can set a default for all users this way:
[HKEY_LOCAL_MACHINE\SOFTWARE\Martin Prikryl\WinSCP 2]
"DefaultUpdatesPeriod"=dword:00000000
