Topic "Bug: External Application Patterns PORT missing"
harkman
Hello.
WinSCP Version: 5.2.2
The external application path setting allows new patterns. I'm missing a pattern for not-standard ports. My server is running SSH on a different port and while launching Kitty over the Registry key does work, launching it via commandline will end with a Network error: Connection refused.
what is the Pattern to define the port after the host? Or maybe you could implement the !@ pattern to expand to <host>:<port>
Regards, Jrgen
Thanks for your post.
This request has been added to the tracker:
http://winscp.net/tracker/show_bug.cgi?id=1020
harkman
Thank you.
Regards, Jrgen
harkman
Please don't forget this one. Seems such a small bug but renders the kitty launching nearly useless for me and maybe som other people too.
Thanks, Jrgen
