Topic "421 Can't create socket"
Socko71
I can't connect to my production DMZ machine with WINSCP but I can through Filezilla. I included log of both am I missing a setting?
2013-07-19 15:04:27 4072 3 Status: Resolving address of WB-IISIFBEB-PRD
2013-07-19 15:04:27 4072 3 Status: Connecting to 192.168.252.14:21...
2013-07-19 15:04:27 4072 3 Status: Connection established, waiting for welcome message...
2013-07-19 15:04:27 4072 3 Response: 220-FileZilla Server version 0.9.39 beta
2013-07-19 15:04:27 4072 3 Response: 220-written by Tim Kosse (Tim.Kosse@gmx.de)
2013-07-19 15:04:27 4072 3 Response: 220 Please visit https://sourceforge.net/projects/filezilla/
2013-07-19 15:04:27 4072 3 Command: AUTH TLS
2013-07-19 15:04:27 4072 3 Response: 234 Using authentication type TLS
2013-07-19 15:04:27 4072 3 Status: Initializing TLS...
2013-07-19 15:04:27 4072 3 Status: Verifying certificate...
2013-07-19 15:04:30 4072 3 Command: USER migrprd
2013-07-19 15:04:30 4072 3 Status: TLS/SSL connection established.
2013-07-19 15:04:30 4072 3 Response: 331 Password required for migrprd
2013-07-19 15:04:30 4072 3 Command: PASS **********
2013-07-19 15:04:30 4072 3 Response: 230 Logged on
2013-07-19 15:04:30 4072 3 Command: SYST
2013-07-19 15:04:30 4072 3 Response: 215 UNIX emulated by FileZilla
2013-07-19 15:04:30 4072 3 Command: FEAT
2013-07-19 15:04:30 4072 3 Response: 211-Features:
2013-07-19 15:04:30 4072 3 Response: MDTM
2013-07-19 15:04:30 4072 3 Response: REST STREAM
2013-07-19 15:04:30 4072 3 Response: SIZE
2013-07-19 15:04:30 4072 3 Response: MLST type*;size*;modify*;
2013-07-19 15:04:30 4072 3 Response: MLSD
2013-07-19 15:04:30 4072 3 Response: AUTH SSL
2013-07-19 15:04:30 4072 3 Response: AUTH TLS
2013-07-19 15:04:30 4072 3 Response: PROT
2013-07-19 15:04:30 4072 3 Response: PBSZ
2013-07-19 15:04:30 4072 3 Response: UTF8
2013-07-19 15:04:30 4072 3 Response: CLNT
2013-07-19 15:04:30 4072 3 Response: MFMT
2013-07-19 15:04:30 4072 3 Response: 211 End
2013-07-19 15:04:30 4072 3 Command: PBSZ 0
2013-07-19 15:04:30 4072 3 Response: 200 PBSZ=0
2013-07-19 15:04:30 4072 3 Command: PROT P
2013-07-19 15:04:30 4072 3 Response: 200 Protection level set to P
2013-07-19 15:04:30 4072 3 Status: Connected
2013-07-19 15:04:30 4072 3 Status: Retrieving directory listing...
2013-07-19 15:04:30 4072 3 Command: CWD /\
2013-07-19 15:04:30 4072 3 Response: 250 CWD successful. "/" is current directory.
2013-07-19 15:04:30 4072 3 Command: PWD
2013-07-19 15:04:30 4072 3 Response: 257 "/" is current directory.
2013-07-19 15:04:30 4072 3 Command: TYPE I
2013-07-19 15:04:30 4072 3 Response: 200 Type set to I
2013-07-19 15:04:30 4072 3 Command: PORT 10,100,2,242,226,167
2013-07-19 15:04:30 4072 3 Response: 200 Port command successful
2013-07-19 15:04:30 4072 3 Command: MLSD
2013-07-19 15:04:30 4072 3 Response: 150 Opening data channel for directory list.
2013-07-19 15:04:30 4072 3 Response: 226 Transfer OK
2013-07-19 15:04:30 4072 3 Status: Directory listing successful
2013-07-19 15:04:34 4072 3 Status: Disconnected from server
WINSCP
. 2013-07-19 15:06:07.417 --------------------------------------------------------------------------
. 2013-07-19 15:06:07.417 WinSCP Version 5.1.4 (Build 3020) (OS 6.1.7600)
. 2013-07-19 15:06:07.417 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2013-07-19 15:06:07.417 Local account: IFB\migrprd
. 2013-07-19 15:06:07.417 Working directory: D:\Application\WinSCP
. 2013-07-19 15:06:07.417 Command-line: "D:\Application\WinSCP\WinSCP.exe"
. 2013-07-19 15:06:07.417 Time zone: Current: GMT-4, Standard: GMT-5, DST: GMT-4, DST Start: 3/10/2013, DST End: 11/3/2013
. 2013-07-19 15:06:07.417 Login time: Friday, July 19, 2013 3:06:07 PM
. 2013-07-19 15:06:07.417 Session name: wb-iisifbeb-prd.infarmbureau.com (Modified stored session)
. 2013-07-19 15:06:07.417 Host name: wb-iisifbeb-prd.infarmbureau.com (Port: 21)
. 2013-07-19 15:06:07.417 User name: (Password: No, Key file: No)
. 2013-07-19 15:06:07.417 Tunnel: No
. 2013-07-19 15:06:07.417 Transfer Protocol: FTP
. 2013-07-19 15:06:07.417 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2013-07-19 15:06:07.417 Proxy: none
. 2013-07-19 15:06:07.417 FTP: FTPS: Explicit TLS; Passive: Yes [Force IP: A]
. 2013-07-19 15:06:07.417 Local directory: D:\Application\jenkins\scripts, Remote directory: /, Update: Yes, Cache: Yes
. 2013-07-19 15:06:07.417 Cache directory changes: Yes, Permanent: Yes
. 2013-07-19 15:06:07.417 DST mode: 1; Timezone offset: 0h 0m
. 2013-07-19 15:06:07.417 Username prompt (no username provided)
. 2013-07-19 15:06:14.792 Connecting to wb-iisifbeb-prd.infarmbureau.com ...
. 2013-07-19 15:06:14.855 Connected with wb-iisifbeb-prd.infarmbureau.com, negotiating SSL connection...
< 2013-07-19 15:06:14.855 220-FileZilla Server version 0.9.39 beta
< 2013-07-19 15:06:14.855 220-written by Tim Kosse (Tim.Kosse@gmx.de)
< 2013-07-19 15:06:14.855 220 Please visit https://sourceforge.net/projects/filezilla/
> 2013-07-19 15:06:14.855 AUTH TLS
< 2013-07-19 15:06:15.902 234 Using authentication type TLS
. 2013-07-19 15:06:16.230 SSL connection established. Waiting for welcome message...
> 2013-07-19 15:06:16.230 USER migrprd
< 2013-07-19 15:06:16.230 331 Password required for migrprd
> 2013-07-19 15:06:25.011 PASS **********
< 2013-07-19 15:06:25.027 230 Logged on
> 2013-07-19 15:06:25.027 SYST
< 2013-07-19 15:06:25.027 215 UNIX emulated by FileZilla
> 2013-07-19 15:06:25.027 FEAT
< 2013-07-19 15:06:25.027 211-Features:
< 2013-07-19 15:06:25.027 MDTM
< 2013-07-19 15:06:25.027 REST STREAM
< 2013-07-19 15:06:25.027 SIZE
< 2013-07-19 15:06:25.027 MLST type*;size*;modify*;
< 2013-07-19 15:06:25.027 MLSD
< 2013-07-19 15:06:25.027 AUTH SSL
< 2013-07-19 15:06:25.027 AUTH TLS
< 2013-07-19 15:06:25.027 PROT
< 2013-07-19 15:06:25.027 PBSZ
< 2013-07-19 15:06:25.027 UTF8
< 2013-07-19 15:06:25.027 CLNT
< 2013-07-19 15:06:25.027 MFMT
< 2013-07-19 15:06:25.027 211 End
> 2013-07-19 15:06:25.027 PBSZ 0
< 2013-07-19 15:06:25.027 200 PBSZ=0
> 2013-07-19 15:06:25.027 PROT P
< 2013-07-19 15:06:25.027 200 Protection level set to P
. 2013-07-19 15:06:25.074 Connected
. 2013-07-19 15:06:25.074 --------------------------------------------------------------------------
. 2013-07-19 15:06:25.074 Using FTP protocol.
. 2013-07-19 15:06:25.074 Doing startup conversation with host.
> 2013-07-19 15:06:25.136 PWD
< 2013-07-19 15:06:25.136 257 "/" is current directory.
. 2013-07-19 15:06:25.199 Changing directory to "/".
> 2013-07-19 15:06:25.199 CWD /
< 2013-07-19 15:06:25.199 250 CWD successful. "/" is current directory.
. 2013-07-19 15:06:25.199 Getting current directory name.
> 2013-07-19 15:06:25.199 PWD
< 2013-07-19 15:06:25.199 257 "/" is current directory.
. 2013-07-19 15:06:25.449 Retrieving directory listing...
> 2013-07-19 15:06:25.449 TYPE A
< 2013-07-19 15:06:25.449 200 Type set to A
> 2013-07-19 15:06:25.449 PASV
< 2013-07-19 15:06:25.449 421 Can't create socket
. 2013-07-19 15:06:25.449 Could not retrieve directory listing
* 2013-07-19 15:06:25.574 (ECommand) Error listing directory '/'.
* 2013-07-19 15:06:25.574 Could not retrieve directory listing
* 2013-07-19 15:06:25.574 Can't create socket
. 2013-07-19 15:06:28.215 Startup conversation with host finished.
. 2013-07-19 15:06:36.309 Disconnected from server
You are using FTP active mode with Filezilla, while passive mode with WinSCP:
http://winscp.net/eng/docs/ui_login_connection
Socko71
So how could you tell filezilla was active mode? Oh and I changes WINSCP to use active mode (-passive=off) and it worked.
In the log, you can see Filezilla is using PORT command (active mode), while WinSCP was using PASV command (passive mode).
