Topic "Error when uploading an Evaulted file"
mbrijun
I have discovered a problem when trying to upload a file that has been archived with Symantec Enterprise Vault. WinSCP is giving an error message "System Error. Code: 2250. This network connection does not exist" followed by "A call to an OS function failed".
WinSCP version 5.1.5
Filezilla does not seem to have this problem, it gets the source machine to download the file from Evault and then proceeds to upload it via FTP.
mbrijun
here it goes...
. 2013-07-23 13:14:03.763 --------------------------------------------------------------------------
. 2013-07-23 13:14:03.763 WinSCP Version 5.1.5 (Build 3261) (OS 5.2.3790 Service Pack 1)
. 2013-07-23 13:14:03.763 Configuration: C:\Program Files\winscp515\WinSCP.ini
. 2013-07-23 13:14:03.778 Local account: xxxxxxxxxx
. 2013-07-23 13:14:03.778 Working directory: C:\Program Files\winscp515
. 2013-07-23 13:14:03.778 Process ID: 4048
. 2013-07-23 13:14:03.778 Command-line: "C:\Program Files\winscp515\WinSCP.exe"
. 2013-07-23 13:14:03.778 Time zone: Current: GMT+0, Standard: GMT+0, DST: GMT+0, DST Start: 27/10/2013, DST End: 27/10/2013
. 2013-07-23 13:14:03.778 Login time: 23 July 2013 13:14:03
. 2013-07-23 13:14:03.778 --------------------------------------------------------------------------
. 2013-07-23 13:14:03.778 Session name: FILE001 (Stored session)
. 2013-07-23 13:14:03.778 Host name: AA.BB.CC.DD (Port: 21)
. 2013-07-23 13:14:03.778 User name: admin (Password: Yes, Key file: No)
. 2013-07-23 13:14:03.778 Tunnel: No
. 2013-07-23 13:14:03.778 Transfer Protocol: FTP
. 2013-07-23 13:14:03.778 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2013-07-23 13:14:03.778 Proxy: none
. 2013-07-23 13:14:03.778 FTP: FTPS: None; Passive: Yes [Force IP: A]
. 2013-07-23 13:14:03.778 Local directory: E:\Inputs\Austria, Remote directory: /Inputs/Austria, Update: Yes, Cache: Yes
. 2013-07-23 13:14:03.778 Cache directory changes: Yes, Permanent: Yes
. 2013-07-23 13:14:03.778 DST mode: 1; Timezone offset: 0h 0m
. 2013-07-23 13:14:04.060 Connecting to AA.BB.CC.DD ...
. 2013-07-23 13:14:04.122 Connected with AA.BB.CC.DD. Waiting for welcome message...
< 2013-07-23 13:14:04.122 220-FileZilla Server version 0.9.41 beta
< 2013-07-23 13:14:04.122 220-written by Tim Kosse (Tim.Kosse@gmx.de)
< 2013-07-23 13:14:04.122 220 Please visit http://sourceforge.net/projects/filezilla/
> 2013-07-23 13:14:04.122 USER xxxxxxxxxxx
< 2013-07-23 13:14:04.122 331 Password required for xxxxxxxxxx
> 2013-07-23 13:14:04.122 PASS ***********
< 2013-07-23 13:14:04.122 230 Logged on
> 2013-07-23 13:14:04.122 SYST
< 2013-07-23 13:14:04.122 215 UNIX emulated by FileZilla
> 2013-07-23 13:14:04.122 FEAT
< 2013-07-23 13:14:04.122 211-Features:
< 2013-07-23 13:14:04.122 MDTM
< 2013-07-23 13:14:04.122 REST STREAM
< 2013-07-23 13:14:04.122 SIZE
< 2013-07-23 13:14:04.122 MODE Z
< 2013-07-23 13:14:04.122 MLST type*;size*;modify*;
< 2013-07-23 13:14:04.122 MLSD
< 2013-07-23 13:14:04.122 AUTH SSL
< 2013-07-23 13:14:04.122 AUTH TLS
< 2013-07-23 13:14:04.122 PROT
< 2013-07-23 13:14:04.122 PBSZ
< 2013-07-23 13:14:04.122 UTF8
< 2013-07-23 13:14:04.122 CLNT
< 2013-07-23 13:14:04.122 MFMT
< 2013-07-23 13:14:04.122 211 End
. 2013-07-23 13:14:04.185 Connected
. 2013-07-23 13:14:04.185 --------------------------------------------------------------------------
. 2013-07-23 13:14:04.200 Using FTP protocol.
. 2013-07-23 13:14:04.200 Doing startup conversation with host.
> 2013-07-23 13:14:04.247 PWD
< 2013-07-23 13:14:04.263 257 "/" is current directory.
. 2013-07-23 13:14:04.310 Changing directory to "/Inputs/Austria".
> 2013-07-23 13:14:04.310 CWD /Inputs/Austria
< 2013-07-23 13:14:04.341 250 CWD successful. "/Inputs/Austria" is current directory.
. 2013-07-23 13:14:04.341 Getting current directory name.
> 2013-07-23 13:14:04.341 PWD
< 2013-07-23 13:14:04.372 257 "/Inputs/Austria" is current directory.
. 2013-07-23 13:14:04.622 Retrieving directory listing...
> 2013-07-23 13:14:04.622 TYPE A
< 2013-07-23 13:14:04.622 200 Type set to A
> 2013-07-23 13:14:04.622 PASV
< 2013-07-23 13:14:04.638 227 Entering Passive Mode (AA,BB,CC,DD,23,113)
> 2013-07-23 13:14:04.638 MLSD
< 2013-07-23 13:14:04.685 150 Connection accepted
< 2013-07-23 13:14:04.685 226 Transfer OK
. 2013-07-23 13:17:55.138 Directory listing successful
> 2013-07-23 13:18:25.966 PWD
< 2013-07-23 13:18:26.466 257 "/Inputs" is current directory.
. 2013-07-23 13:18:37.497 Copying 1 files/directories to remote directory "/Inputs/"
. 2013-07-23 13:18:37.497 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2013-07-23 13:18:37.497 TM: B; ClAr: No; CPS: 0; InclM:
. 2013-07-23 13:18:37.497 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2013-07-23 13:18:37.497 File: "E:\Inputs\test.xls"
* 2013-07-23 13:18:37.513 (EOSError) A call to an OS function failed
. 2013-07-23 13:18:37.513 Asking user:
. 2013-07-23 13:18:37.513 File or folder 'E:\Inputs\test.xls' does not exist. ("A call to an OS function failed")
* 2013-07-23 13:18:42.138 (EOSError) A call to an OS function failed
. 2013-07-23 13:18:42.138 Asking user:
. 2013-07-23 13:18:42.138 File or folder 'E:\Inputs\test.xls' does not exist. ("A call to an OS function failed")
* 2013-07-23 13:18:43.997 (EOSError) A call to an OS function failed
. 2013-07-23 13:18:43.997 Asking user:
. 2013-07-23 13:18:43.997 File or folder 'E:\Inputs\test.xls' does not exist. ("A call to an OS function failed")
* 2013-07-23 13:18:45.419 (EScpSkipFile) File or folder 'E:\Inputs\test.xls' does not exist.
* 2013-07-23 13:18:45.419 A call to an OS function failed
. 2013-07-23 13:18:45.419 Retrieving directory listing...
> 2013-07-23 13:18:45.419 TYPE A
< 2013-07-23 13:18:45.450 200 Type set to A
> 2013-07-23 13:18:45.450 PASV
< 2013-07-23 13:18:45.481 227 Entering Passive Mode (AA,BB,CC,DD,23,117)
> 2013-07-23 13:18:45.481 MLSD
< 2013-07-23 13:18:45.528 150 Connection accepted
< 2013-07-23 13:18:45.528 226 Transfer OK
. 2013-07-23 13:18:49.060 Disconnected from server
Thanks.
