Topic "WinSCP doesn't save last window state"
Spark
Since the last two updates, my WinSCP 5.1.6 (Build 3394) every time opens up at an unusual window size and the file list is filtered by change date.
If I resize the window, filter the list by name and then close and reopen WinSCP, I have the same start again.
So WinSCP doesn't remember my last Window settings.
What can I do to fix this?
Spark
email sent Smile
Spark
I have no file received yet Sad
You had INI file both in Program Files folder (where you did not have write permissions). WinSCP was reading the configuration from there. But when writing, the old versions (you were using before upgrade) were writing to your user profile folder (due to Windows feature called file virtualization). This was prevented since 5.0.1 as it caused lots of confusion:
http://winscp.net/tracker/show_bug.cgi?id=719
But the change caused troubles as well, as people had (unwrittable) INI files in program files, what made WinSCP show error now. So there was another change in 5.2 that made WinSCP fall back to user profile:
http://winscp.net/tracker/show_bug.cgi?id=817
That's shortly why 5.2.3 works for you, 5.1.6 does not and 4.x did Smile
I hope it makes sense.
