WinSCP Tunnel
sheauyun
WinSCP Tunnel
Hi there,
Anyone is using the WinSCP Tunnelling with the .dll?
I had tried for a while and noticed that I am getting get ssh hostkey get thru intermittently. Sometime I am able to execute it successfully but at another time, I will get it fail all the time. Who knows what is the problem?
Thanks!
. 2013-07-31 10:43:31.296 --------------------------------------------------------------------------
. 2013-07-31 10:43:31.296 WinSCP Version 5.1.2 (Build 2816) (OS 5.1.2600 Service Pack 3)
. 2013-07-31 10:43:31.296 Configuration: C:\Program Files\WinSCP\winscp.ini
. 2013-07-31 10:43:31.296 Local account: PLEXUSHPENANG8\omneonadmin
. 2013-07-31 10:43:31.296 Working directory: C:\Program Files\WinSCP
. 2013-07-31 10:43:31.296 Command-line: "C:\Program Files\WinSCP\winscp.exe" /xmllog="C:\Documents and Settings\omneonadmin\Local Settings\Temp\wscp2764.0232467A.tmp" /xmlgroups /nointeractiveinput /dotnet=515 /log="C:\Program Files\Omneon\DiagnosticTest\WinSCPLog.txt" /console /consoleinstance=_10084_631
. 2013-07-31 10:43:31.296 Time zone: Current: GMT-7, Standard: GMT-8, DST: GMT-7, DST Start: 3/10/2013, DST End: 11/3/2013
. 2013-07-31 10:43:31.296 Login time: Wednesday, July 31, 2013 10:43:31 AM
. 2013-07-31 10:43:31.296 Session name: root@172.31.1.6 (Ad-Hoc session)
. 2013-07-31 10:43:31.296 Host name: 172.31.1.6 (Port: 22)
. 2013-07-31 10:43:31.296 User name: root (Password: Yes, Key file: No)
. 2013-07-31 10:43:31.296 Tunnel: Yes
. 2013-07-31 10:43:31.296 Tunnel: Host name: 172.16.1.26 (Port: 22)
. 2013-07-31 10:43:31.296 Tunnel: User name: root (Password: Yes, Key file: No)
. 2013-07-31 10:43:31.296 Tunnel: Local port number: 0
. 2013-07-31 10:43:31.296 Transfer Protocol: SCP
. 2013-07-31 10:43:31.296 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2013-07-31 10:43:31.296 Proxy: none
. 2013-07-31 10:43:31.296 SSH protocol version: 2; Compression: No
. 2013-07-31 10:43:31.296 Bypass authentication: No
. 2013-07-31 10:43:31.296 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2013-07-31 10:43:31.296 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2013-07-31 10:43:31.296 SSH Bugs: A,A,A,A,A,A,A,A,A,A
. 2013-07-31 10:43:31.296 SFTP Bugs: A,A
. 2013-07-31 10:43:31.296 Return code variable: Autodetect; Lookup user groups: A
. 2013-07-31 10:43:31.296 Shell: default
. 2013-07-31 10:43:31.296 EOL: 0, UTF: 2
. 2013-07-31 10:43:31.296 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2013-07-31 10:43:31.296 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2013-07-31 10:43:31.296 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2013-07-31 10:43:31.296 Cache directory changes: Yes, Permanent: Yes
. 2013-07-31 10:43:31.296 DST mode: 1
. 2013-07-31 10:43:31.296 Opening tunnel.
. 2013-07-31 10:43:31.296 Autoselected tunnel local port number 50000
. 2013-07-31 10:43:31.312 [Tunnel] Looking up host "172.16.1.26"
. 2013-07-31 10:43:31.312 [Tunnel] Connecting to 172.16.1.26 port 22
. 2013-07-31 10:43:31.328 [Tunnel] Server version: SSH-2.0-dropbear_0.50
. 2013-07-31 10:43:31.328 [Tunnel] Using SSH protocol version 2
. 2013-07-31 10:43:31.328 [Tunnel] We claim version: SSH-2.0-WinSCP_release_5.1.2
. 2013-07-31 10:43:31.328 [Tunnel] Using Diffie-Hellman with standard group "group1"
. 2013-07-31 10:43:31.328 [Tunnel] Doing Diffie-Hellman key exchange with hash SHA-1
. 2013-07-31 10:43:31.406 [Tunnel] Verifying host key rsa2 0x10001,0xa7d158950332d996235f428c8340df6f089cdaa629236f2180694123f17b7a406d4c88d25511f75419556fb8e88d5325e11e8aadfc22c123cecdc6b561bbcebe2739fb6c6ac7b5be5f1f0ef06fc055d5cda68378eae3fed28c8dff4b46b44e283525557e63bc64ce15bc3bb9528237ef04142a175c25bf21dab1d584446fa8dde4dd with fingerprint ssh-rsa 1040 9e:26:55:a0:a6:83:1b:99:65:20:fa:19:0b:79:bc:dc
. 2013-07-31 10:43:31.406 Asking user:
. 2013-07-31 10:43:31.406 The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is.
. 2013-07-31 10:43:31.406 The server's rsa2 key fingerprint is:
. 2013-07-31 10:43:31.406 ssh-rsa 1040 9e:26:55:a0:a6:83:1b:99:65:20:fa:19:0b:79:bc:dc
. 2013-07-31 10:43:31.406 If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
. 2013-07-31 10:43:31.406 Continue connecting and add host key to the cache? ()
. 2013-07-31 10:43:31.421 [Tunnel] Closing connection.
. 2013-07-31 10:43:31.421 [Tunnel] Sending special code: 12
