Topic "FTPS transfers very slow for many small files"
Sharken
I am transferring a lot of small files (20.000) using Implicit FTPS on port 990.
Transfer is extremely slow, there is a visible delay between each individual file transfer.
If i compare with FileZilla the difference is massive. Apparently WinSCP is doing something that
is hurting performance when copying lots of small files.
Hopefully this behavior can be improved, as it is unusable for a large amount of small files as it is.
This was tested on version 5.2.2 (Build 3365).
I believe you are a victim of this bug:
http://winscp.net/tracker/show_bug.cgi?id=1021
It is fixed in 5.1.6 and will be fixed in 5.2.3 beta.
Sharken
Great news, will be testing 5.2.3 beta then
Sharken
Just finished testing 5.2.3 beta and it hasn't improved the situation.
It seems that even the WinSCP GUI is slow when copying many small files. No more than 3-4 files
is copied each second, which is way too slow when you have 20k+ files to copy.
I cant really give any further info, there seems to be some kind of overhead for each file, that
prevents the filecopy processs from running fast :/
Sharken
Email with logfile have been sent to you now, i hope that it will help you locate the issue.
Sharken
Tracefile with additional debugging info sent.
tomb
I was the first victim of this bug 1021
It was indeed solved in 5.1.6. With this bug solved I transferred 2800 small files in 17 min: about 3 files/sec. This is fast enough for me. With the bug it took several hours.
It seems that WINSCP has quite a lot of overhead for transferring one file. I hope it is identified as a new bug and that the overhead can be reduced.
http://winscp.net/tracker/show_bug.cgi?id=1058
Sharken
Can confirm the bug has been fixed, very pleased with how the bug was handled and ultimately fixed.
Thanks !
tomb
So it seems the bug 1058 is solved in 5.1.8. I have the same performance issue in FTP and SFTP with a transfer speed of at most 3-4 files/sec. I wonder if this bug and fix is specifically for FTPS. Does anyone know this? I am waiting for the release of 5.1.8 to test it myself
Sharken
According to http://winscp.net/eng/docs/history#5.2.4 the fix will be included in 5.1.8/5.2.5 beta. Note that neither of these has been released yet.
Please start a new topic and attach a complete session log file showing your problem. Separately for FTP and SFTP. Thanks.
tomb
I just did a short test with SFTP and FTP and found an SFTP speed of 20-25 files/sec for tiny files. That is much faster than FTP and fully adequate for me.
I will start a new topic for the slow FTP.
