Topic "Retrieve Exit Code from Session.ExecuteCommand"
mxcolin
I'm using ExecuteCommand on the Session class to call a command remotely however I cannot get at the exit code?
CommandExecutionResult result = session.ExecuteCommand(command.Executable + " " + command.Arguments);
Will throw a SessionRemoteException if the command fails but there's no way to know what the exit code is?
Colin
No, indeed there's no way to retrieve the exit code.
mxcolin
Nuts Sad
mxcolin
Any plans for adding this in anytime soon?
Will consider it. Meanwhile you can dump the exit code to the command output and parse it out yourself.
