Topic "WinSCP360"
KurĐ+
I have a problem with new 3.6 version
I have 2 configured connections with two hosts.
The 1st connection doesn't use proxy server. The 2nd does. The problem ist with the 2nd connection, when I click login i get an error:
Assertion failed: frontend, file D:\Martin\Projekty\WinSCP2\core\net.cpp, line 64
and than
Abnormal program termination
sometime i get also an error:
Assertion failed: Configuration, file D:\Martin\Projekty\WinSCP2\core\SecureShell.cpp, line 978
If you need more info, let me know, please.[/code]
KurD+
More info:
Log:
. WinSCP Version 3.6.0 (Build 217) (OS 5.0.2195 Service Pack 4)
. Login time: Freitag, 7. Mai 2004 13:55:36
. Session name: Home Compression
. Host name: **************** (Port: 443)
. User name: ******** (Password: Yes, Key file: No)
. Transfer Protocol: SCP
. SSH protocol version: 2 only; Compression: Yes
. Ping type: N, Ping interval: 60 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: HTTP
. HostName: ********* (Port: 3128); Username: ; Passwd: No
. Shell: /bin/sh, EOL: 0
. Local directory: E:\, Remote directory: /cygdrive, Update: No, Cache: Yes
. Cache directory changes: Yes, Permanent: Yes
. Looking up host "*************"
. Connecting to ************** port 443
* (EAccessViolation) EAccessViolation
Thanks for your info. I think I do not need more information now. I'll ask if I need.
Have exact the same prob - any hints yet ? - BTW. MP your prog is a Genius Brain dump - what would we all do without it ? Very Happy
After testing new 3.6.0 always the above error occurs.
Win XP Pro system, and only the file.exe downloaded, not complete new install.
Greets Ron
There is no help. It is a bug. I have fixed it already. Please wait for the next release (few days)
Or send an email to me and I'll send you back the fixed version. I would like to have it tested before release (I do not have any proxy to test it myself). This of course applis to KurD+ as well.
KurD+
So I've tested the new version, it works very well with proxy (HTTP Proxy, I couldn't test with other type of proxy server).
Another question or actually two, if I have two transfers in background and I decide to delete one transfer it's working, but if I have one background transfer and I start second transfer (but not background) and then I decide to delete the "nobackground" transfer, winscp disconnect from server so the background transfer is also disconnected, is this feature from design or some type of bug?
2. I think, it would be nice to see also transfer rate in the background transfers window, not only amount of data transfered. It's only a suggesion.
Best Wishes
It is by design. But it happens only for SCP protocol. With SFTP you may cancel the transfer without closing the whole connection. Personally I do not use SCP anymore, so until now I even haven't realized the implication you describe.
I consider that.
frodet
Seems like this is much of the same, but with socks (socks5) instead.
. WinSCP Version 3.6.1 (Build 221) (OS 5.1.2600 Service Pack 1)
. Login time: 14. mai 2004 14:06:35
. Session name: ft
. Host name: xxxxxx.net (Port: 22)
. User name: ft (Password: Yes, Key file: No)
. Transfer Protocol: SFTP (SCP)
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. Proxy: SOCKS5
. HostName: proxy.xx (Port: 1080); Username: ; Passwd: No
. Shell: default, EOL: 0
. Looking up host "xxxxxx.net"
* (ESshFatal) gethostbyname: unknown error
I'm sorry, but I do not know how to help you with this Sad
Did you specify on proxy settings:
"Do DNS name lookup at proxy end": YES ?
Thanks. Seems that did the trick! Very Happy
You welcome:)
KurD+
