Topic "add Comment field on Login Window"
izet68
Sometimes you wish to put comments about machine you are about to connect to. If you have many similar machines then it is really helpful to put remainder about the machine in comment section. it can be also called Description...
Thanks!
Izet
Thanks for your suggestion.
This request has been added to the tracker:
http://winscp.net/tracker/show_bug.cgi?id=1043
