Topic "Transfering files without using temp files in VB Script"
geethanaik
I am trying to sftp file to the destination server through VB Script written for WinSCP. I am able to send smalle files ~10 KB without any issue but when i try to send bigger file ~300 KB, the file transfered is having a .filepart extention. Is there anyway to transfer files without using the temporary filenames. I have tried the below options but nothing works.
TransferOptions.ResumeSupport = TransferResumeSupport_off
TransferOptions.ResumeSupport = off
TransferOptions.TransferResumeSupport = off
Correct syntax is:
TransferOptions.ResumeSupport.State = TransferResumeSupportState_Off
See
http://winscp.net/eng/docs/library_com_wsh#enums
http://winscp.net/eng/docs/library_transferresumesupport
http://winscp.net/eng/docs/library_transferoptions
geethanaaik
Thank you.
