Topic "GetFiles Not Throwning Exception"
JasonRkr
WinSCP 5.1.7.0
windows Server 2003 R2 with SP2
Sftp
Scripting / Automating
Downloading a file from a remote directory does not throw an exception when the file does not exist.
Here's the result from the PowerShell window:
PS C:\WINDOWS\system32\WindowsPowerShell\v1.0> C:\scripts\labQCFileDownload.ps1
Transfers Failures IsSuccess
{} {} True
Another user in .NET assembly / COM library (http://winscp.net/forum/viewtopic.php?t=12773) is experiencing the same issue with putFiles, but I don't know what version of WinSCP he's running.
try
    # Load WinSCP .NET assembly
    # Use "winscp.dll" for the releases before the latest beta version.
    [Reflection.Assembly]::LoadFrom("\\C:\scripts\WinSCP.dll") | Out-Null
    # Setup session options
    $sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
    $sessionOptions.HostName = "xxxxxxxx"
    $sessionOptions.UserName = "xxxxxxxx"
    $sessionOptions.Password = "xxxxxxxx"
    $sessionOptions.SshHostKeyFingerprint = "ssh-rsa 2048 0e:2b:76:24:bf:50:e7:29:f5:01:2b:e6:59:16:ea:10"
    $session.AdditionalExecutableArguments = "/xmllog='c:\temp\lab_qc_log.xml'"
    $session.DebugLogPath = "c:\temp\lab_qc_debug.log"
    $session.SessionLogPath = "c:\temp\lab_qc_session.log"
    $session.XmlLogPath = "c:\temp\lab_qc_sessionxml.xml"
    $session.ExecutablePath = "c:\scripts\winscp.exe"
    try
        # Connect
        $stamp = Get-Date -f "yyyyMMdd"
        $fileDay = Get-Date -Format "dd"
        $fileName = "FTP20*"
        $remotePath = "/U/softprint/$fileName"
        $localPath = "c:\lab_qc\$fileName"
        $session.GetFiles($remotePath, $localpath)
    catch [Exception]
        Write-Host $_.Exception.Message
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    exit 1
You have to call TransferOperationResult.Check.
See http://winscp.net/eng/docs/library_session#results
JasonRkr
Sorry, I should have added that I also tried with .Check() and it still failed to throw an exception.
Jason
And I should have notices your dump of the Session.GetFiles result.
Please attach a complete session log file.
