Topic "Change log level with command line parameter?"
g24ftp
I have a problem with logging my file transfers.
I am using a batch-file where I execute the following script.
set WrkDir=C:\WinSCP
set BatchFile=%WrkDir%\Test.batch
set LogFile=%WrkDir%\Test.log
@echo>%BatchFile% option echo on
@echo>>%BatchFile% option batch abort
@echo>>%BatchFile% option confirm off
@echo>>%BatchFile% option reconnecttime off
@echo>>%BatchFile% option transfer binary
@echo>>%BatchFile% open User@123.123.123.123
@echo>>%BatchFile% ls
@echo>>%BatchFile% exit
"C:\WinSCP\winscp.com" /script=%BatchFile% /log=%LogFile%
Some time ago the log-files started to get pretty big, like 700mb log-file for a 170mb file.
So I perhaps the default log-level has changed.
So is there a special parameter or command to change the log-level for a transfer, I could use in this line:
winscp.com /script=%BatchFile% /log=%LogFile%
I am using version 5.1.4, but I tested this scenario with the newest version, too (5.1.7)
There's not such parameter.
See http://winscp.net/eng/docs/faq_script_ini
g24ftp
I changed this line as described here to set the log level to the lowest http://winscp.net/eng/docs/rawsettings
@echo>>%BatchFile% open User@123.123.123.123 -rawsettings LogProtocol=0
But it still uses the debug level 2 logging if that is set in the .ini.
If I understand the rawsetting function right it should overwrite the .ini settings. Is that correct?
No. The LogProtocol is not site setting. It's global. So you should follow the section for "Other Settings":
