Topic "Problem with Timestamp - Using Scripts"
ahofmann
Hi there,
i use WinSCP in some Batchfiles (.bat) to connect to an SFTP Server , now since we have "Summer Time" (Daylight Saving Time) the time of the files is one hour off the real time.
I found some document (https://faq.webspace-verkauf.de/article/weshalb-wird-bei-der-nutzung-von-winscp-eine-falsche-uhrzeit-timestamp-angezeigt.html) that i should switch this one setting in the options of Winscp.
MY PROBLEM:
I can change this setting, and save it then as a file, but how can i change the default setting in the program, so that my scriptfiles that use WinSCP also take the new setting and not the default one.
Thank you very much,
Andre
Duplicate post:
http://winscp.net/forum/viewtopic.php?t=12804
